Bias/dark frames - color tint - light leak through multiple blankets?
6 replies to this topic
#1 maxsid
maxsid
  • Loc: Sunnyvale, CA
Posted 23 January 2021 - 10:12 PM
Hello,
I started to create a bias/dark library today.
I used to collect my bias/dark frames only if I needed a new set and was doing this outside after sunset.
This time I decided to collect the whole library in one run for different gains/offsets/exposures indoors.
What I notices is that indoors all bias/dark fames had a significant blue tint.
This was pretty surprising as the scope was covered with a cover cap and several blankets.
The tint was there even for very short exposure bias frames.
Does this tint even matter? (I think it does).
Can the day-light really penetrate cover/blankets? (looks like it really can).
Master bias shot in the dark (scope cover cap and additional tarp on too)
Master bias shot indoors during daytime (scope cover cap and additional tarp and two thin blankets on)
#2 bobzeq25
bobzeq25
Posted 23 January 2021 - 11:55 PM
Basic mistake.  Those histograms are "stretched" data.  The program you're using automatically stretches the data as far as it needs to so you can see something.  The appearance of a light link may be only due to that.  Probably is.
What you want to look at is the linear histogram.  For bias, it will be just about a vertical line, separated from the lefthand edge only by the camera offset, often 300-600 ADU.  Not a gaussian curve unless you expand the x-axis.
Suitable programs are IRIS and PixInsight.  There are others.
I stick the lens cap on and throw my regular telescope over the setup.  Works fine with an astro specific camera, with a DSLR you'll want to get a viewfinder cover, light can leak in that way.
https://www.amazon.c.../dp/B06XSJGJB5/
Edited by bobzeq25, 23 January 2021 - 11:58 PM.
#3 DJL
DJL
Posted 24 January 2021 - 11:00 AM
Did you ever do film and paper photo processing? Would blankets have been good enough to make a darkroom? No, you needed a completely dark room with no light leaks around doors and windows. You could use a red light for the print, but for film you needed total darkness.
I used a dark filter in a filter wheel plus the telescope end cap and took darks in the daylight. The enclosed is a screenshot from Mac Observatory's finder FITS preview, which is autostretched, and hence has a lot of color noise but it does show the light leak. I used these darks and ended up with weird burned out parts in the resulting stacks.
So I still use my filter wheel for darks, but I do so at night, automated at the end of the light run, still at night, or switch over to darks when clouds appear. With a cooled camera I can save darks for different bias and exposure length.
#4 maxsid
maxsid
Posted 24 January 2021 - 08:28 PM
Yes I did and quite a lot. Photo-plates too. Before CCD cameras it was a big part of my professional activity.
Edited by maxsid, 24 January 2021 - 08:54 PM.
#5 maxsid
maxsid
Posted 24 January 2021 - 08:44 PM
Oh, no. You got me wrong.
I understand histograms and stretching well.
What surprised me was that the light really goes through the end cap, blankets and tarp in a dimly lighted room.
What is even more surprising - just a cap and the cap plus multiple additional layers of light protection produce almost identical results.
I learned my lesson and made my conclusions.
My questions were not about what's going on or what to do but:
Is this possible? Yes.
Does it matter? I think - yes. It has to  be done in the dark.
Thank you!
Edited by maxsid, 24 January 2021 - 09:17 PM.
#6 ChrisWhite
ChrisWhite
  • Loc: Northeast USA
Posted 24 January 2021 - 08:54 PM
Looks like you figured it out, but I was going to suggest you could have light entering through the optical viewfinder as well....
#7 maxsid
maxsid
Posted 24 January 2021 - 09:16 PM
Oh.. guys. Sorry. I got right results but interpreted them wrong.
It was the latest software update which screwed things up - reverted my white-balance in ZWO camera driver back to default.
Mine was WB_R=50 WB_B=50, default is WB_R=52 WB_B=95 which produces twice as much blue.
