Has anybody successfully fit all eight Ethos in an Apache 4800 case? Please show your layout.
Ethos and Apache 4800 will they fit?
#1
Posted 25 January 2021 - 03:45 PM
#2
Posted 25 January 2021 - 04:39 PM
Eight lb+ Apache 4800 itself plus ~10lb+ eight Ethoi = ~18lb total weight... wow, nice workout before observing
#3
Posted 25 January 2021 - 04:51 PM
Edited by jmillsbss, 25 January 2021 - 04:54 PM.
#5
Posted 25 January 2021 - 05:46 PM
This is a 4800. I know it's not a set of Ethos. I imagine they would require much more space than I did. I wish I had another picture that showed before I laid it out in this manner. I had them "standing in the case" and the 6/8 Delos and 31 Nagler barely had a half inch of foam top and bottom in that configuration.Have you tried a layout in MyCaseBuilder.com? It's a cool way to lay it out and all it costs is your time. It's helpful.
Yes, I did a layout on mycasebuilder.com. It's very, very close.
I was hoping to see that someone else had successfully taken the plunge.
#6
Posted 25 January 2021 - 10:11 PM
I understand and I felt like my longer body EPs were protected fine sitting there in the case, upright, but I couldn't find peace of mind regarding transport or God forbid dropping the case, with only a half inch of condensed pluck foam on each end. I just had to lay them all down. The 5800 is quite a bit bigger and it was considered, but if I'd bought the 5800 I'd have to fill it up with more eyepieces! I swore I would wear out these first!
- wrvond likes this
#7
Posted 27 January 2021 - 01:39 PM
I ended up getting a Pelican 1600 case.
I wanted to carry all 8 Ethos, the Paracorr, and all my filters in one case.
Around 30 lbs, I think, but it easily had room for that.
https://www.cloudyni...ases/?p=7118385
There was enough room for an alignment eyepiece, and collimation tools, and SQMs in the case, too.
The case has been re-foamed now and has even more stuff in it.
- wrvond likes this
#8
Posted 27 January 2021 - 05:06 PM
Don, is there anything around the same size (L X W) but a little less height?
The P1600 is like 7" deep.
#9
Posted 27 January 2021 - 05:43 PM
I found this:
https://www.amazon.c...e/dp/B00JVA7RNI
It's 18.9 x 16.3 x 6
Compared to a Pelican 1600, which is 21.5 x 16.5 x 8
So the Monoprice case is shallower. I wouldn't go thinner than 6" or there will be inadequate top and bottom protection around the 21 Ethos or a 31 Nagler if they are stored lying down.
- wrvond likes this
#10
Posted 27 January 2021 - 05:48 PM
I found this:
Almost perfect......except the internal measurements are a little less (under 6"). Still might be ok....
#11
Posted 27 January 2021 - 07:47 PM
The Pelican Air series is quite a bit lighter than the traditional Pelicans. I have a full set of Ethos in a Pelican Air 1525. The case weighs in under 6lbs. I’m not sure what the total weight is but you could do a quick calculation using the Televue eyepiece specifications table on their website. While it accommodates the full Ethos series, other accessories would need to go in a separate case. Inside dimensions are 20.5 x 11.3 x 6.75.
#13
Posted 27 January 2021 - 09:49 PM
I found this:
For less than $83.00 that looks like a pretty good deal!
