I need to replace the LNT module on my older ETX125 (has the side lens). No luck finding one so far, nor can I find the newer module that has the red dot lens on the top. Any suggestions?
my first post to the group.
Thank you
Posted 25 January 2021 - 04:32 PM
Thank you
Posted 26 January 2021 - 08:23 PM
Posted 26 January 2021 - 08:27 PM
Posted 26 January 2021 - 09:14 PM
If you're needing to replace the LNT because it's "dead" perhaps all you need is a new battery for the module; a CR2032 I believe (could be wrong tho).
Posted 26 January 2021 - 11:00 PM
Check with eBay seller scopehed. They have listed a RedDot model in the past.
Greg
I shall do so, thanks.
Posted 26 January 2021 - 11:02 PM
I lost the lens (but can get one) however the very small fibre optic thread on the side broke off, with out that the whole unit is pooched. I could likely use a later module but can’t find that either.
Posted 26 January 2021 - 11:38 PM
Posted 27 January 2021 - 09:06 AM
Without the lens and the optic cable being broke, the only feature lost is the red dot scope. As far as I know the LNT part still functions as it should. Seems there's not a lot of information out on the LNT. Think I also read that the LNT module is not really needed. I suggest a Title Only search and see what comes up.
Posted 28 January 2021 - 10:40 AM
Thank you. I will set it up and look for a finder scope to add to the scope.
![]() Cloudy Nights LLC Cloudy Nights Sponsor: Astronomics |
