Building 10Micron models and the things that affect models
139 replies to this topic
#126 Tonk
Tonk
  • Loc: Leeds, UK, 54N
Posted 18 April 2021 - 07:57 PM
I see you explicitly mentioned that number for the first model but didn't for the second model.
I called it a "small" model on both occasions - therefore same rules - its in the name (I'm a programmer : ) ). You are just iteratively repeating the process until "convergence". When your PA error is <1 arc min your are basically converged enough - and unless you have a floppy mirror scope that will happen in two passes if it hasn't happened on the first
For the final model, how many points do you recommend for 600s unguided with a rigid fsq-85? I was thinking between 50 and 60.
You can't recommend - its a function of many factors to do with you specific mount and scope as what you can get away with. Easiest answer is always as many as you can do - mine are always 80+ - and that is for a Tak TOA130. Experiment - try small and large and see what you get. With my TV85 I can use a 25 point model for 10 minutes unguided but that has a wider FOV. Note your points should be evenly spread of course.
Edited by Tonk, 18 April 2021 - 08:03 PM.
  • psandelle, durak and Raginar like this
#127 vdb
vdb
Posted 19 April 2021 - 02:42 AM
ModelCreator and 2 iterations of 12 points, 35 Arcsec polar aligned.
It really is that easy.
I finally had a couple of hours clear sky, so I ran a 12 point model and the person running the remote centred the mount, the mount was of by almost 2 degrees, luckily this was a wide field imaging setup. After that initial run the next model reported 3 minutes of the pool. Quick 12 point run and it brought it further down to 35 seconds ...
With a 12 point model I can easily do 5 minute unguided imaging.
And each slew lands the object dead center.
/Yves
Edited by vdb, 19 April 2021 - 02:48 AM.
  • Tonk, psandelle and yzhzhang like this
#128 SimonIRE
SimonIRE
  • Loc: South East England
Posted 19 April 2021 - 03:00 AM
/Yves
Yep - told ya! ;)
#129 SimonIRE
SimonIRE
Posted 19 April 2021 - 04:22 AM
Incidentally, if you want to guide it's incredibly easy.
I went to bed at 21:00 last night. I had Voyager set to start imaging at 21:30.
Dual tracking on, exposures in PHD2 set to 10s. I didn't fiddle with any of the other PHD2 settings.
Image scale was 0.65"/pixel
Full frame sensor (QHY600)
One push of a button
Here was my guiding-
Screenshot 2021 04 19 At 09.02.45
so if you want to guide, it's easy to do so.
  • durak likes this
#130 Tonk
Tonk
Posted 19 April 2021 - 05:41 AM
Also note that if you came from the Losmandy world and have used either the Gemini I or Gemini II controllers, then the model building and polar aligning is *exactly* the same procedures as used in the 10Micron. I came this route and hence found using the 10Micron incredibly easy.
The only thing that flumoxed me when I got my first 10M in 2013 was the lack on PEC on the handset. I had no idea what absolute encocders were then - so it wasn't the selling point at all - it was seeing that the model building and PA procedure were familiar to me and it didn't need me to cart around a laptop. It was my uber mobile setup!
When I did finally twig that it had absolute encoders and what it did, I realised I'd bought a gem of a mount. smile.gif
PS I love unintentional puns.
Edited by Tonk, 19 April 2021 - 05:42 AM.
  • psandelle, Raginar, Greg F and 1 other like this
#131 SimonIRE
SimonIRE
Posted 19 May 2021 - 12:56 PM
Bump.
Any interesting new 10 Micron model building news or observations?
#132 FredOS
FredOS
Posted 20 May 2021 - 05:38 PM
More of a question but as I see your example with 10s guiding and using voyager, I was wondering how you manage to dither as it probably takes a lot of time to settle with 10s guide frames ?
Edited by FredOS, 21 May 2021 - 04:18 AM.
#133 Raginar
Raginar
  • Loc: Pensacola, FL
Posted 20 May 2021 - 06:01 PM
More of a question but as I see your example with 10s guiding and using voyager, I was wondering how you manage to dither as it proabaly takes a lot of time to setlte with 10s guide frames ?
Never thought about that.  I'm interested to hear how they solve that.
#134 SimonIRE
SimonIRE
Posted 23 May 2021 - 06:35 AM
I’ve only started dithering recently but I understand the question and I’m not sure I have an answer...
#135 FredOS
FredOS
Posted 24 May 2021 - 04:58 PM
I have been going unguided which facilitated dithering. I plan to go with OAG guiding which leaves two options : (1) shorter guide frames of 4/5 s, (2) drop dithering. With an ASI 6200 I’m unclear what you lose we no dithering.
#136 Lead_Weight
Lead_Weight
  • Loc: Houston
Posted 24 May 2021 - 05:38 PM
I'm sure there are still dead/bad pixels which could cause fixed pattern noise. So dithering is still good to do. There's a bunch of imaging apps out there that can do non-guide dither pulses for dithering without guiding. I use EKOS and it has that feature in the guiding preferences.
#137 FredOS
FredOS
Posted 25 May 2021 - 12:05 PM
Agree. Non-guide is managed by several applications (I use SGPro and Voyager). Question is more about what to do when guiding.
#138 alphatripleplus
alphatripleplus
    World Controller
  • Loc: Georgia
Posted 25 May 2021 - 02:24 PM
Everyone please remember this is not an imaging forum. If you have questions regarding the pros/cons of various general imaging decisions unrelated to 10Micron mount models, please ask them in an imaging forum. Thanks.
#139 Raginar
Raginar
Posted 26 May 2021 - 11:44 AM
https://www.cloudyni...o=new_post&f=76
Since we have issues with this every 37 days or so, I created a thread in the imaging forum linked above.
#140 bortle2
bortle2
Posted 28 May 2021 - 05:08 AM
The above link just tries to create a new topic, unfortunately.
Correct link is https://www.cloudyni...hread-catchall/
... and BTW thanks for that new thread.
