iOptron 2" tripod to SkyGuider mismatch?
mount equipment tripod
11 replies to this topic
#1 PlateSolver2021
PlateSolver2021
Posted 26 January 2021 - 09:02 PM
Has anyone had this problem before? I bought the iOptron 2" tripod that claimed to be compatible with the SkyGuider Pro, but it only came with an unthreaded stud that is too big and not removeable. Seems like a mismatch. ???
  • teashea likes this
#2 Jim Waters
Jim Waters
  • Loc: Phoenix, AZ USA
Posted 26 January 2021 - 09:26 PM
Return it.  The center rod should be threaded.
#3 chanrobi
chanrobi
Posted 26 January 2021 - 09:32 PM
The rods bottom is threaded, is it upside down?
#4 PlateSolver2021
PlateSolver2021
Posted 26 January 2021 - 09:39 PM
Chanrobi, I thought the same thing, however that thread size is too large too. :(
#5 scadvice
scadvice
  • Loc: Lodi, California
Posted 26 January 2021 - 10:29 PM
Check to see if there is an adapter to screw on the thread stud. When I had a Sky Guilder in the package I recall there was ID to OD adapter. Also look to see if the mounts female thread doesn't unscrew to a larger size. That's all I got...
Edited by scadvice, 26 January 2021 - 10:31 PM.
  • Jim Waters and PlateSolver2021 like this
#6 teashea
teashea
  • Loc: Lincoln, Nebraska, USA
Posted 26 January 2021 - 10:47 PM
Another example where the lack of standardization is a pain.
  • Jim Waters, alancraig and PlateSolver2021 like this
#7 Jim Waters
Jim Waters
Posted 26 January 2021 - 11:30 PM
Return it and get your money back.
  • PlateSolver2021 likes this
#8 junomike
junomike
  • Loc: Ontario
Posted 27 January 2021 - 08:28 AM
Looks like they sent the wrong one.  This Tripod lacks the center pin and is spec'd as compatible with the Skyguider Pro.
#9 alancraig
alancraig
  • Loc: Roswell, GA & Bradenton, FL, USA
Posted 27 January 2021 - 11:11 AM
FYI—The tripod you linked does have a center bolt with 3/8 thread (according to the tech specs), and the off center alignment peg would need to be removed for the SkyGuider.  I like the weasel wording in the listing though—“This tripod may fit with the following mounts”
#10 Tom3
Tom3
  • Loc: Scottsdale, AZ
Posted 27 January 2021 - 11:13 AM
As it says in the link this is for a ZEQ or CEM mount.  I have a CEM 25 and from what I can see of my tripod I don't see any way you can fit a Sky Guider onto it.   I use a Manfrotto tripod for my Sky Guider.
#11 alancraig
alancraig
Posted 27 January 2021 - 11:24 AM
Have you contacted the seller or iOptron?  I would be interested to know if it is a defective product (too large/non-threaded bolt), or simply a tripod meant for another mount.
As a newbie to this field, I am amazed at how careful one must be in selecting gear that will work together—even from the same vendor.
#12 junomike
junomike
  • Loc: Ontario
Posted 27 January 2021 - 12:20 PM
Looks like this is one for iOptron to answer.  Thanks for the info.
Also tagged with one or more of these keywords: mount, equipment, tripod
