I've mentioned this a couple of times in a thread or two, but I think it is time to make a thread about this all of its own.
IT IS POSSIBLE TO HAVE A DEW-FREE corrector plate without needing to use heat. Not one joule of heat.
We stuff around so much to get our scopes to acclimate and also insulate our scopes to slow the rate of cooling, and then we go and stick heating elements all around it. Worse still the way heating elements are used they are most inefficient by wrapping the heat source around a metal tube...
I have a big dew problem where I live. Home is where I do the majority of my lunar and planetary observing. I live directly across from a heavily irrigated park whose lush green fields creates an especially humid microclimate all around it. While the official dew point may be lower than the ambient, the moisture rich air coming from the park sees the surrounding streets soaking wet with dew. It also doesn't help that my own backyard is turfed and with a lush vegie patch - dew is a constant battle for me.
I have been insulating my SCT's and Maks for several years now. While this has helped me rip high magnification straight away upon setting up and has slowed the dewing process considerably, the corrector plate of these scopes will still dew up if the conditions are right (which is most nights). I had used a hair drier for a number of years to deal with this, but it is only a temporary measure and it gets wearisome to be constantly getting up to dry off the dew... Plus I have not been a fan of using heat on my optics so its been a love-hate situation.
There had to be an alternative.
This alternative has been staring me in the face for YEARS!!! FANS!
First, professional observatories do not use heat to keep their equipment dry if dew is a likely problem on any given night. Instead they use fans to push air all around their equipment making use of the evaporative power of moving air to dry things off. By also only using fans they do not introduce unwanted heat and infrared interference into their equipment, not just for their cameras but also for the thermo-mechanical stability of the entire structure - different materials have different coefficients of expansion, and in the complex large structure of a professional scope, thermal stability means all the materials shrink/expand at predictable rates and amounts. Start introducing heat and this predictability goes out the window. How fans are used in professional observatories is critical too as these can cause thermal issues in materials too if incorrectly implemented.
Second, I have been utilising this principle of using fans on my open dobs and solid tube Newts for a number of years too. I have had my scopes Newt optics stay bone dry while those of others have called it a night because of dew. So how could I use this with my Cats???
The solution was so simple for me. As I insulate my Maks with Coreflute, this material could be easily cut to accommodate a small 40mm 12V fan approx 50mm to 75mm in front of the corrector. The fan is then wedge into the side of the dew-sheild end of the insulating wrap in such a way that it blows a vortex of air inside the dewshield compartment. This vortex provides not just movement of air, but the corrector is also not subjected to a localized thermal strain from having a cold stream of air blow directly onto one spot on it.
12V was a no-brainer as it is already what I use to power the mount. As an added bonus, the amount of power a 40mm fan uses is next to nothing compared to a heating strap even at lower power. And also cheaper and easier to purchase, install and work with than a dew strap and controller be it commercially made or DIY.
I have been using this method for close to a year now with my Maks and refractors and have not had to stop a viewing session early because of dew.
Vibrations? Nope. None at all. Not even with the Mak pushing 560X.
The day after my proof of concept first use of this fan system I thought "why couldn't this work with a refractor too?". Well, it can. I replaced the metal dewshield that came with the frac and replaced it with one made from Coreflute and installed a 40mm 12V fan to it, and PRESTO! It works a treat too, and NO HEAT!
I have also attached a PWM unit so I can regulate the RPM's.
I do not need to use the fan every night of course as dew formation varies from night to night. I also don't turn it on until I feel I need to. If the corrector does start to dew up I just switch it on and the dew is dried off in a matter of moments.
You do not need to use Coreflute to make use of this method of dew control. As long as you have a way of securing the fan inside of the dewshield you have made then it will work.
Alex.
Edited by maroubra_boy, 01 February 2021 - 07:11 PM.
