those long slow refractors give you that velvet black back ground that just makes stars pop.
classic super planetary scopes
#51
Posted 09 February 2021 - 09:12 PM
- steve t and catboat like this
#52
Posted 09 February 2021 - 09:37 PM
Long slow scopes are better for deep sky in my book. My 4" F/15 Unitron just had a way of showing deep sky objects like no other scope. Super contrast and a dark sky back ground made M13 come alive. Sure don't need fast optics for good deep sky unless it is very low power wide field sweeping for very big objects.
This was the telescope that John Mallas chose for his Sky Survey. All the visual observations of the Messier objects found in his book, The Messier Album, were done with a Unitron 4". His drawings show the amount of detail that he could capture with this telescope. I have observed the Messier objects with my own 4" Carton refractor. Long focus refractors are indeed excellent for deep sky objects.
- clamchip, steve t, Bonco2 and 1 other like this
#55
Posted 09 February 2021 - 11:59 PM
I built my first 4-1/4 Kutter Schief back in 1971. Definitely a "planet killer". When I exhibited at RTMC Roland came over, took a long look and commented "perfect just perfect". I lost that scope in 1991 in the Oakland hills fire! (lost our home also!) A few years ago I came across an ad here on CN selling a Lichtenknecker 5 inch Schief. Made the purchase and have been happy ever since. So my vote is for these instruments. Unique, affordable, and will definitely cause strange looks!
- philipdo, mattyfatz, Jeff B and 17 others like this
#56
Posted 10 February 2021 - 07:29 AM
from bonco2
"Had a wonderful 6 inch f/8 Astro Physics triplet. Loved it in every way. BUT after a side by side view of Jupiter with it and a RV6, I saw the view was superior in the RV6."
wow never thought i hear that!
i have rv6
did this shot of mars you can see mons (bright spot) yes RV6 is good
but to be compared with high end refractor like AP sheesh!
- mattyfatz, clamchip, steve t and 8 others like this
#57
Posted 10 February 2021 - 07:37 AM
from bonco2
i have rv6
Maybe have been an exceptional RV6 or a poorly collimated AP.
- Defenderslideguitar likes this
#58
Posted 10 February 2021 - 07:16 PM
from bonco2
i have rv6
I had his RV6 and it was just as good as two 6" ED's i had. Even sharper than a super sharp 826.
- steve t, deepwoods1, catboat and 2 others like this
#59
Posted 10 February 2021 - 08:49 PM
the simpler the optics the better the results can be if they are a perfect sphere.
- steve t likes this
#60
Posted 10 February 2021 - 11:57 PM
There is no denying that large refractors are expensive. But then there is something magical about a large refractor that is hard to beat.
Guilty on both counts.
Besides giving exceptional solar system object views, large refractors can give amazing deep sky views, and, I feel, are completely underrated for that.
Jeff
- highfnum, clamchip, steve t and 11 others like this
#62
Posted 11 February 2021 - 06:33 AM
what is an 826?
#63
Posted 11 February 2021 - 06:47 AM
what is an 826?
Meade 8" F/6 Newt from around 1979 to 1983.
- Bomber Bob and Defenderslideguitar like this
#64
Posted 11 February 2021 - 08:47 AM
Sweet setup, Jeff!!
#65
Posted 11 February 2021 - 09:11 AM
jeff what is make on that scope?
#66
Posted 11 February 2021 - 09:24 AM
lovely set up Jeff B very clean looking
BTW my rv6 is blushing from all the compliments
Thanks.
Be careful though, about your RV-6 blushing as it will be accused of CA in the red and, thus, its wonderful views will be completely discounted, disparaged and dismissed by some of the "experts" here.
Jeff
#67
Posted 11 February 2021 - 09:25 AM
Jeff B Optical.
- combatdad and jcruse64 like this
#68
Posted 11 February 2021 - 09:49 AM
you ground lenses?
#70
Posted 11 February 2021 - 09:53 AM
does that scope have some sort of skin problem?
- steve t and Bomber Bob like this
#71
Posted 11 February 2021 - 09:56 AM
Previous owner gave it a new skin: Black, dark gray, & light gray speckles on white Contact Paper... It's pretty in person with the gray & black 80mm RFT + gray & black mount/pedestal.
- mattyfatz likes this
#72
Posted 11 February 2021 - 10:01 AM
from bonco2
i have rv6
When you look at the theoretical performance of 6" f/8 Newtonian vs a 6" f/10 APO, guess,what , the Newtonian has a better performance. So when made correctly you will get extremely good planetary image. The problem is that many times the optics are subpar so they get a bad reputation. The APO gives a better image not because of the optical design but most likely the optics are better figured . You also have to factor in the emotional factor that expensive refractors add into the judgment of the image quality vs a true results.
I saw this first hand many times. A typical example was that we have a 4.5" Clark refractor at Mt Cuba Observatory. For many years people ranted and raved about the great image. Said it was the best they ever saw. It is Clark so it has to be amazing. Right ? A simple star test showed the lens had issues. It was taken to D&G Optics back in the early 90's and tested. The figure was bad no surprise too me. D&G refigured it and it was mention in a couple of their Ads in Sky and Tel at the time. Now it gives a very nice image. It was the emotional factor that was distorting the true about the image quality.
The bottom line is many optical designs can be excellent planetary scopes , but to be one they must have very well figured optics.
- Dave
Edited by DAVIDG, 11 February 2021 - 02:58 PM.
- gnabgib, highfnum, Jeff B and 7 others like this
#73
Posted 11 February 2021 - 10:28 AM
you ground lenses?
Ha, ha, ha, ha, ha, ha,
No. I've neither the skill and, more importantly, the patience, for such a task.
The objective is a D&G Optical 11" F12 (F12.3 actually) achromat. Sadly, it seems Barry is no longer making lenses and tube assemblies for us consumers anymore.
The tube assembly was tinkered together by me about 11 years ago from bits and parts I had or scrounged on the net. The current mounting (there has been a considerable evolution in mounts for this scope) is a Parallax 250 Observatory Series mount with an Astro-Physics control system. As you see it, it is now housed in an observatory, for private and public use, that is dedicated to my late wife.
It is capable of, and has provided, some stunning solar system views, seeing and thermal conditions permitting. I also have a suite of Chromacor color correctors that I employ with it along with a similar suite of aperture stops to help improve the color performance of the system and better match the aperture to the prevailing seeing conditions.
My most satisfying ATM project really.
Jeff
- highfnum, mattyfatz, Jim Curry and 15 others like this
#74
Posted 11 February 2021 - 10:43 AM
The flip side of the I paid $1000 per inch of aperture so my new APO must out-perform my other scopes, is what I've experienced buying used & very cheap reflectors: How good can a $150 Newt be??
I found out the first time I turned my 1971 RV-6 to Saturn. I was in such a rush, I hadn't even cleaned the scope first. I was stunned by the views! No problem justifying the improvements; and, when you spent so little on the old reflector, it's easier (to me) to spend more $$$ improving its performance. Ditto for the equally cheap 1980s Meade 826. I've spent about 3x its original cost on making it an even better old reflector. With no regrets at all.
But... there were times when my $3000 2017 APM 152ED showed more fine details on Jupiter than my 826 -- both scopes at 400x. Was that bit of extra performance worth 10x the price? Yes! The Planets aren't around that much, so getting the best views possible during those brief periods was priceless to me... Were the differences due to the APM's superior optics? I don't think so. Jupiter & Saturn were LOW this season. Mars was much higher in the sky, and my 826, RV-6, and Tinsley 6 Cass all performed very well at up to 60x per inch. I'm no Reflector Expert, but I think that puts all 3 in the Super Planetary category.
- steve t, PawPaw, Bonco2 and 3 others like this
#75
Posted 11 February 2021 - 10:56 AM
wow 11inch refractor that's a beast
what does ota weigh?
