Nosepiece for the Celstron SCT Turret
25 replies to this topic
#1 Tom Duncan
Tom Duncan
  • Loc: Chico, CA
Posted 18 February 2021 - 04:40 PM
Over the years I've had several of these 1980's Celestron "Multiple Ocular Holder"'s (aka 'turret') made by Vixen and though neat I've let them go, partially because the are for SCT's only. The most recent one is in nearly mint condition and I have a nice set of Meade RG's to fill it up so I'm going to hang on to it for a while. However if I could insert it into a standard drawtube (either 2" or 1.25") I'd be even more inclined to keep it and use it.
So my question is, does anyone make an adapter to do so? The SCT tube threads right off revealing male threads of 39.8mm OD (peak to peak). I'm hoping I can find a tube with female threads to fit that and on the other end have either a 1.25" or 2" nosepiece.
Anyone know of a solution?
Tom Duncan
  • Bomber Bob and LU1AR like this
#2 starman876
starman876
    Nihon Seiko
  • Loc: VA
Posted 18 February 2021 - 04:43 PM
I am sure there is a way to adapt it.  Look into the Baader  adapters.  I still have one of these also.  Think I will check it out to see if it can be adapted.
#3 J A VOLK
J A VOLK
  • Loc: Flagstaff
Posted 18 February 2021 - 04:50 PM
looks like maybe filled with RG eyepieces!
  • Don W likes this
#4 ngc7319_20
ngc7319_20
  • Loc: MD
Posted 18 February 2021 - 05:02 PM
I use a Baader ring #28 to reduce the Schmidt-Cass thread to standard T-thread.  Then put a T-thread to 2" camera adapter on it.  So you end up with something that plugs into a standard 2" inlet on a refractor.
https://alpineastro....gth-t-2-part-28
https://alpineastro....big-t-2-part-16
There are probably other ways to do it...
Edited by ngc7319_20, 18 February 2021 - 05:04 PM.
  • Bomber Bob and firemachine69 like this
#5 Foundationer
Foundationer
  • Loc: Central US
Posted 18 February 2021 - 08:16 PM
I want that! When are you gonna put it
#6 Tom Duncan
Tom Duncan
  • Loc: Chico, CA
Posted 18 February 2021 - 08:37 PM
Yep!
I'm going to hang on to it for a while, I really want to see this attached to the drawtube of my refractors. As an aside these show up once in a while in the CN and Am ads, usually hovering around $100.
Thanks for the suggestion, I'll look into that.
Edited by Tom Duncan, 18 February 2021 - 08:38 PM.
  • Bomber Bob and Foundationer like this
#7 RichA
RichA
  • Loc: Toronto, Canada
Posted 18 February 2021 - 08:44 PM
Be way more impressive than Baader's plastic job filled with modern orthos.
#8 davidmcgo
davidmcgo
  • Loc: San Diego, CA
Posted 18 February 2021 - 09:30 PM
There are a number of 2” to SCT thread adapters available. Will make it a little longer but should work OK if the refractor can handle a 2” diagonal.
https://agenaastro.c...19-2408155.html
Dave
  • ngc7319_20 likes this
#9 Bomber Bob
Bomber Bob
  • Loc: The Swamp, LA (Lower Alabama)
Posted 19 February 2021 - 01:06 PM
Tom, on my NOS vintage Vixen SCT turret, all that SCT hardware comes off, and an old Celestron (Vixen) chrome 1.25" barrel from a prism diagonal threads in:
I got mine cheap in part because the 4 slots are for .965" eyepieces.  Not a problem for me - got plenty of quality eyepieces in that small barrel size.
Edited by Bomber Bob, 19 February 2021 - 04:44 PM.
  • Kasmos, petmic, LU1AR and 1 other like this
#10 photoracer18
photoracer18
  • Loc: Martinsburg, WV
Posted 19 February 2021 - 05:16 PM
Tom Duncan
Meade has been making 2" to SCT thread adapters since at least the early days of the 102/127/152/178 ED/APO refractors because they recommended using the SCT .63x reducers on them from the start. I have been using one of the Celestron turrets in my refractors off and on for a couple of years this way. This is the newest version of one I think from Lumicon.
Edited by photoracer18, 19 February 2021 - 05:26 PM.
  • Bomber Bob, dhkaiser and LU1AR like this
#11 Tom Duncan
Tom Duncan
  • Loc: Chico, CA
Posted 19 February 2021 - 07:38 PM
I'll look into that, thanks.
Looks like the construction is quite a bit different with the Vixen .965" version. There are female threads on the inside of the back plate but they are too large for a 1.25" nosepiece.
Edited by Tom Duncan, 19 February 2021 - 07:38 PM.
#12 luxo II
luxo II
  • Loc: Sydney, Australia
Posted 19 February 2021 - 07:57 PM
LOL you can still buy TEC turrets. But you can't buy one of these anymore
  • LU1AR likes this
#13 blippincott
blippincott
  • Loc: Kyle Tx
Posted 25 December 2021 - 07:44 PM
Hi.
   I've had a Celestron turret lying around for about 18 months and I finally decided to see about using it in my D&G. I looked at the solutions presented on the various forums and decided to figure this one out for myself. I have a machine shop at home, and there was some aluminum stock leftover from building parts for my Dobsonian. (No, I don't consider that cheating --- it's taking advantage of opportunities that present themselves.) wink.gif
  Some concerns for me were to minimize any extension of the turret by adding adapters with a lot of spacing to the end of the draw tube. There is little in-focus room left with a 25mm Plossl, about 1/4". I also wanted to not cut on or modify the stock turret assembly if possible, in case I decide to sell it later. As of this post it is still able to be used on an SCT just as intended.
   The adapter piece is held on by the original nose piece going through the center of it, and clamped in place by the small flange on the end that was for the original threaded ring. I just removed the ring and made the adapter to slip over the outside, with cut reliefs for both ends. this allowed me to get the turret body right up against the back surface of the draw tube. Shortest length I could manage, and it worked perfectly. grin.gif
   The very last pic shows where I added a safety catch undercut to the 1.25" long 2" long adapter. It could be shortened as far as 1" in length if need be, but 1.25" gives the longest contact distribution down the tube length for the best alignment.
   My solution is pictured below:
  • astro140, Tom Duncan, Dave Trott and 4 others like this
#14 Tom Duncan
Tom Duncan
  • Loc: Chico, CA
Posted 26 December 2021 - 11:43 AM
I should have kept the Unimat I had for a while long ago...
  • Don W and blippincott like this
#15 petmic
petmic
  • Loc: Slovakia
Posted 04 March 2023 - 10:28 AM
I am just wondering, do these turrets have a prism or a mirror diagonal inside?
#16 deSitter
deSitter
    Still in Old School
Posted 05 March 2023 - 09:37 AM
My Meade (Japan) 4-banger has a prism. I assume it's the same manufacture. Very nice device. I should use it more.
I did find a SCT to 2 in. nosepiece. If someone wants to see it, give a word.
-drl
Edited by deSitter, 05 March 2023 - 09:38 AM.
  • petmic likes this
#17 deSitter
deSitter
    Still in Old School
Posted 05 March 2023 - 09:40 AM
Is that Van Slyke? Very steampunk ethos :)
-drl
#18 petmic
petmic
  • Loc: Slovakia
Posted 05 March 2023 - 01:07 PM
-drl
Yes, please. Although, I would need 1.25 nosepiece. Not sure if such exists. How much does it increase the light path comparing to a ordinary prism? Is it significant?
#19 deSitter
deSitter
    Still in Old School
Posted 05 March 2023 - 01:41 PM
The prism is made for 1.25" eyepieces but allows the complete pencil without vignetting. Its best feature is the prism. But its worst feature is being stuck with 1.25". It is good for doing detailed lunar/planetary and switching among 4 similar powers. In practice I almost always use a 2" prism diagonal.
-drl
  • petmic likes this
#20 petmic
petmic
  • Loc: Slovakia
Posted 05 March 2023 - 01:45 PM
-drl
Well, I would like to adapt that turret for a long refractor with a 1.25" focuser. No quite sure if a suitable nosepiece can be found though.
#21 deSitter
deSitter
    Still in Old School
Posted 09 March 2023 - 08:33 AM
I have something like this - not this but the same size and format. It screws into the retaining ring on the SCT turret/diagonal. My Meade turret was made for their SCTs. It adds the width of the retaining ring to the light path, IOW very little.
https://www.optecinc...-inch/17665.htm
-drl
#22 dhkaiser
dhkaiser
Posted 16 May 2023 - 08:03 PM
Found this at a reasonable price...
https://agenaastro.c...txoC6BsQAvD_BwE
#23 balotin
balotin
Posted 16 January 2024 - 01:01 AM
Tom- did you ever find a solution? I have one of these that is missing the SCT nosepiece, would be great if you found a solution you could share…thanks!!/
  • petmic likes this
#24 Tom Duncan
Tom Duncan
  • Loc: Chico, CA
Posted 21 January 2024 - 01:58 PM
Frankly I've forgotten all about this! And no, I never pursued any of the solutions offered as they were either too expensive or, in most cases, out of stock. If you find one of the simple solutions available, especially this one, please let us know.
#25 petmic
petmic
  • Loc: Slovakia
Posted 28 March 2025 - 09:25 AM
I found the solution how to adapt this Vixen eyepiece turret to a 1.25" focuser. The solution was rather simple.
The turret has an extension tube with a flange for SCT 2" thread (female). The other side of this extension tube goes into another adapter with male threads on both sides:
The thread that goes into the turret is the same as a thread on a typical 1.25" diagonal nose piece:
I tried a nose piece from a Celestron branded 1.25" prism and also from a cheap chinese diagonal mirrors. Both fit just fine.
The turret is very solid and nicely made. A typical Vixen product. However, there is one drawback though. The prism is rather small and the clear aperture is only 25mm. Not a problem for me since the widest EP I use is Circle T 20mm Erfle but for EPs with larger filed stop vignetting might be visible.
Also, the light path is shorter than I expected. It is about the same as Baader T2 (non Zeiss) prism with 1.25" EP , i.e. around 70mm.
Edited by petmic, 28 March 2025 - 09:26 AM.
  • Bomber Bob likes this
