Player One Astronomy release Neptune-C II (IMX464) and whole series
9 replies to this topic
#1 Player One Astronomy
    Vendor - Player One Astronomy
Posted 22 February 2021 - 02:20 AM
The Neptune series is a 1/2-inch format planetary camera series for the top player. It is larger than 1/3-inch and has a higher resolution, and is more suitable for astronomy enthusiasts.
The main hit of the Neptune series is Neptune-C II, yes, you read it right. We directly released the second-generation Neptune model on the grounds that the plan could not keep up with the changes.
Neptune-C II camera uses Sony’s latest IMX464 chip, which is better than IMX462.
Neptune-C II is also the world’s first planetary camera with IMX464 chip.
0.7e ultra-low read noise
Compared with the IMX178 of the same frame, the read noise of Neptune-C II can be as low as 0.7e, and the noise is reduced by about 47%, which is as strong as IMX462!
Sensitivity increase
Compared with another 1/1.8 inch chip IMX178, we find that the IMX464 pixel is larger than the IMX178 at 2.4um, reaching 2.9um.
When used on the same telescope, although the quantum efficiency is not much different, the 2.9um pixel has 46% larger photosensitive area than the 2.4um pixel, which can greatly increase the single pixel to obtain more photons, which means Sensitivity has also been greatly improved.
Near infrared super light sensitivity
Not only that, IMX464 also has ultra-sensitive infrared sensitivity characteristics, suitable for playing infrared photography, whether it is matched with IR685, IR850 or CH4 filters, it will give you a new visual experience.
Ultra high frame rate
Neptune-C II can reach 93FPS at full resolution, which is 55% higher than the 60FPS of the IMX178 chip of the same size, making it more efficient to shoot planets.
Beside the brightest star Neptune C II, we also launch another two models of Neptune series.
Neptune-M and Neptune-C, Based on IMX178 sensor, I believe you are familiar with it.
Maybe someone will ask, why make Neptune-M and C when you already have such a strong new camera Neptune-C II?
Reason 1, we need a monochrome camera.
IMX464 sensor is a color sensor, for many enthusiasts, without monochrome camera, a lot of shooting flexibility will be vanished, so Neptune-M is to make up for this.
Reason 2, we need true color.
Because Neptune-C (IMX178 color sensor) does not need to highlight its infrared sensitivity (compared with the IMX464 infrared sensitivity, the point of the IMX178 is very low). So, we put an UV IR-cut protective glass in Neptune-C, return you a pure true color world.
These two models complete our Neptune series, I believe that there will always be one suitable for you.
At last, let’s open the price that everyone cares about most:
#2 Player One Astronomy
Posted 22 February 2021 - 02:27 AM
Features:
The naming of Player One Astronomy cameras is unique. For example, we name the planetary cameras after planets (They are Mercury, Venus, Mars, Jupiter, Saturn, Uranus and Neptune, Earth is not included). The size of each planet to a certain extent, represents the size of camera sensors. We will name Saturn with a 1-inch sensor camera, and for Neptune, we will named it with  a 1/1.8 inch senor camera. All names will be engraved on the housing of the cameras.
Drivers and softwares download: http://player-one-as...rvice/software/
Manuals download: http://player-one-as...ervice/manuals/
Cutting-edge Design
The planetary cameras developed by Player One Astronomy uses a scientific and technological regular hexagon to construct the main body line, supplemented by round chamfers to achieve both rigidity and flexibility. The positive red, which is like a summer fire, is matched with the low-key and steady black, and the super-fine frosting process on the entire surface makes the camera look luxurious and cool, highlighting the style of high-end players, can’t take my eyes off 😀
Sensor Tilt Plate
When taking solar photograph with prominence telescope, the Newton ring is annoying. Smoother solar image without Newton ring could be taken by adjusting the focal plate. Besides, when you use a planetary camera for deep-sky lucky imaging, if you find the surrounding stars are not perfect, you can adjust the sensor tilt plate to obtain a flatter image field. get a much smaller field curvature of the telescope.
The built-in high-density sponge shading pad can block the light from the side slits without any side leakage.
256M DDR3 Cache
Player One Astronomy cameras are the first one who adpots the DDR3 cache in all planetary cameras in the world! It helps stabilize and secure data transmission, it effectively avoids frame dropping and greatly reduces readnoise.
With the DDR3 cache, our camera do not have high demands on computing needs any longer, it will still has excellent performance even if it is connected to a USB 2.0 port.
DPS technology
The planetary cameras from Player One Astronomy have DPS (Dead Pixel Suppression) technology, dead pixels (including both hot pixels and cold pixels) of the image are swept away. DPS function is turned on during your whole imaging session, no need to worry about it !
Overvoltage and overcurrent protection mechanism
Player One cameras produced by the number one player ensures the safety of your camera and other equipment through overvoltage and overcurrent protection mechanisms.
Data Port
When the camera is connected to the USB3.0 interface and full-resolution preview is used, Neptune-C II can reach 93 FPS in RAW8 mode (10bit ADC). When recording images, since the actual writing speed will be affected by the writing speed of the hard disk itself, when the hard disk writing speed is slow, the recording may not reach the theoretical speed. It is recommended that you use a high-quality solid state drive to record data to give full play to the performance of the camera.
Use the ST4 guide cable to connect the camera and the AUTO GUIDE port of the equatorial mount to do guiding.
  • Lead_Weight and Psittacula like this
#3 Olivia
Olivia
Posted 22 February 2021 - 03:09 AM
very nice camera! Seems neither ZWO or QHY have it!!
Anywhere that in Europe can get this camera?
#4 alphatripleplus
alphatripleplus
    World Controller
  • Loc: Georgia
Posted 20 March 2021 - 03:09 PM
Do these cameras come with any type of amp-glow suppression / anti amp-glow circuit?
  • RossW likes this
#5 RossW
RossW
  • Loc: Lake Biwa, Japan
Posted 20 March 2021 - 10:45 PM
Is this the same technology that results in the "star eater" problem? Most importantly, because the problem of hot and cold pixels can be easily dealt with in processing, can this "feature" by turned off (for DSO imaging)?
#6 Player One Astronomy
Posted 06 April 2021 - 04:29 AM
DPS is based on dark frame, thoes pixels are already dead, no response to light signal. In our tech, if there is a star on dead pixel, the dead pixel will be calculate the pixels around it and get a new pixels value. As we know the star can't be only one pixel, so this technology won't eat stars.
#7 Player One Astronomy
Posted 06 April 2021 - 04:37 AM
Amp-glow is suppressed to lowest level in developing the hardware. This is something a professional manufactor must do, not a feature. :)
  • DSO_Viewer likes this
#8 RossW
RossW
Posted 06 April 2021 - 06:30 AM
Can this DPS tech be turned off?
Is DPS implemented by Player One Astronomy, or is it implemented by the chip manufacturer?
#9 Astrojedi
Astrojedi
  • Loc: SoCal
Posted 27 April 2021 - 09:19 AM
Typically by the camera manufacturer.
#10 GSBass
GSBass
  • Loc: South Carolina
Posted 03 May 2021 - 10:22 PM
I would liked to have tried this, feel bad I just purchased the 485c, it does not have the same ir sensitivity as the 462c
