my dew heater has been on for almost 2 years non stop
9 replies to this topic
#1 Tim
Tim
  • Loc: Kitchener, Ontario
Posted 22 February 2021 - 11:35 PM
Since building my observatory and never wanting to have dew or moisture around the optics. With a belief that a little gentle heat is a good thing (no idea if that's true)
I Leave my dew heater on all the time doesn't matter when or the season its always on - medium to low setting. I have never had dew on the optics and it doesn't seem to cause any issues.
Anyone else leave the dew heaters on?
How long can you expect a dew heater to last?
I am guessing the dew heater power supply might go first, really no idea.
#2 alphatripleplus
alphatripleplus
    World Controller
  • Loc: Georgia
Posted 23 February 2021 - 09:08 AM
I have a dew heater that is  a few decades old, but I don't run it 24/7 -only when I set up my scope. I expect it will last  a long time, but I would be worried about checking the power circuit occasionally.
  • Tim likes this
#3 decep
decep
  • Loc: Georgia, US
Posted 23 February 2021 - 08:07 PM
This is probably not a likely failure scenario, but it is the worst case:  your dew heater PWM controller fails and is permanently set on a 100% duty cycle.  Would it be okay to run at 100% for days/weeks unmonitored?
#4 sberrada
sberrada
  • Loc: Montreal, Quebec
Posted 23 February 2021 - 10:27 PM
Hi
i have had mine on for more than 6 months continuously on scopes and mounts.
i cover my scopes with Telegizmo light cover and  keep my dew heaters on.
This is valuable winter and summer
they generate little heat so I am not worried even if they are at 100% for weeks on.
sam
  • Tim likes this
#5 ram812
ram812
  • Loc: Grants Pass, Oregon. Originally Los Osos/Morro Bay, California
Posted 24 February 2021 - 12:35 AM
It would be prudent to at least verify everything is working properly from time to time (Call it scheduled maintenance), I'd rather be safe than sorry😉! Regularly checked, why not?FWIW
CS!
#6 SonnyE
SonnyE
  • Loc: Cali for ni a
Posted 24 February 2021 - 01:05 AM
I think your dew is probably warm and cozy...
You may want to see how things are fairing under the dew strip. You may have cooked the telescopes finish.
  • Tim likes this
#7 Tim
Tim
Posted 25 February 2021 - 10:04 PM
Hi
sam
I typically keep Telegizmo cover over mine to in the observatory in case i get any dew from the ceiling or a possible leak dripping down.   I am going to check the paint - not sure its enough heat to do anything.    I have heard of people putting in a light bulb to add some heat and keep things above ambient temperature.
#8 Wow!
Wow!
Posted 25 February 2021 - 11:47 PM
seems like a waste of power to me. I switch mine on when needed.
#9 dclt
dclt
Posted 25 February 2021 - 11:53 PM
The idea of leaving the dew heaters on all the time seems unnecessary.
  • Wow! likes this
#10 sberrada
sberrada
Posted 27 February 2021 - 10:05 PM
The reason I keep mine on all the time is partially to remove humidity and partially to raise temperature since it is very cold.
I monitor my temperature and humidity in the observatory and it is often at or near 100%.
The temp drops to -20C regularly during peak winter, so a little extra heat helps.
The mild heat helps to keep things dryer but I also keep dessicant inside the Telegizmo.
The cost is negligible - about $2 / month
  • Tim likes this
