Digital Weirdness
5 replies to this topic
#1 BYoesle
BYoesle
  • Loc: Washington USA
Posted 23 February 2021 - 03:39 AM
While this post has an image of the Sun, I'm needing some input from general digital CMOS experts. I recently acquired a FLIR GS3-U3-123S6M 12 MP CMOS monochrome video camera to do full disc imaging of the Sun.
When used at an FL of 900 mm prime focus, the image is essentially perfect:
Coronado SM90/90 > ED100/900 > BF30 > FLIR Grasshopper3, captured with FireCapture, pre-processed in ImPPG, aligned and stacked in AS!3. No additional processing. Click for larger.
However, merely adding a CEMAX 2X Barlow delivered a strange pattern of vertical banding (which I don't think are Newton rings - but I could be wrong) and a irregular patch of fixed pattern noise:
Click for larger.
I'd appreciate any input about what might be causing these artifacts and how they could be eliminated or mitigated.
Thanks for your time and interest.
#2 Tapio
Tapio
  • Loc: Tampere, Finland
Posted 23 February 2021 - 03:45 AM
Those are indeed Newton rings.
See here image (and cure for it too):
https://stargazerslo...-zwo-t2-tilter/
The second is stacking artifact, but I don't remember cure for that.
#3 TOMDEY
TOMDEY
  • Loc: Springwater, NY
Posted 23 February 2021 - 05:24 AM
Yeah, they are unintended ghosting interference fringes exacerbated by the significant longitudinal spatial coherence of the fractional angstrom bandwidth of the etalon. A different Barlow that is specifically V-coated for H-alpha should fix the problem. Probably start by trying different make and model Barlows and/or cheating the spacings to somewhat different amplifications.
Similarities: Lunt makes H-alpha coating optimized Eyepieces. Ideal for your application would be an H-alpha coating optimized Barlow; I'm not sure such exist unless you do the build yourself of commission it. Zygo makes HeNe ARC coated interferometer objectives; I designed and had built custom aerospace Fizeau Interferometer Objectives... and had the shop ARC V-coat for HeNe. As intended, no annoying fringing. The Kodak coating engineer was dragging his feet on the job, so I sent the lenses to my friends at B&L and they did a fine job coating them. Be sure to request the "V-Coat for H-Alpha"; the theoretical achievable ACR is --- identically Zero with 0.05% routinely achieved.   Tom
#4 SandyHouTex
SandyHouTex
  • Loc: Houston, Texas, USA
Posted 23 February 2021 - 10:11 AM
^^^^^ What he said. ^^^^^^
#5 BYoesle
BYoesle
Posted 23 February 2021 - 05:32 PM
Thanks everyone. Like the Lunt eyepieces, the Coronado CEMAX eyepieces and the CEMAX 2X Barlow are actually supposed to have coatings designed specifically for H alpha. But I will try changing the spacings and using different Barlows to cover all the bases.
Looks like a filter-tilter is in my future ;-)
#6 chanrobi
chanrobi
Posted 23 February 2021 - 10:02 PM
Dang, I was just about to say this
