Resetting a StarSense after polar align
3 replies to this topic
#1 Seeker999
Seeker999
  • Loc: Pretoria, South Africa
Posted 23 February 2021 - 03:18 PM
Good day
I use a StarSense unit on my CGEM mount to do a manual plus a polar align.
So I would start with the index markings, point to 5 positions in the sky and have them captured.  I would then add two more alignment positions.
Then I do a polar align and move my mount with the knobs as required.
The HC then shows a message that one should align once again but I am not sure what is the best way to first reset / delete the previous alignment data.
Up to now I have just switched the mount off an on again but that is not ideal.  Any suggestions how to clear out the memory completely and start fresh?
#2 robbieg147
robbieg147
  • Loc: Kent, England
Posted 23 February 2021 - 03:54 PM
Are you doing a manual align because you have a poor view of the sky?
If you have a good view of the sky just do a normal auto Starsense align, if you can see Polaris don't do a ASPA, either use the Polemaster or Sharpcap just a few minutes.
If you have to use ASPA because you cannot see Polaris, just start a new Starsense alignment from the home position, no need to reset anything or turn the mount off.
When I use Starsense I never add additional alignment points just a waste of time, most objects are dead centre. Though if using ASPA there may be some merit in adding points?
Time is precious I would only do a ASPA as a last resort, also this needs to be repeated several times to get good accuracy. Standalone guiders like MGEN can give you a pretty quick PA though have never used mine for this so can't say how well it works?
#3 deansjc
deansjc
Posted 23 February 2021 - 04:44 PM
The above guidance is good.  However, the scope knows where it is pointing after the ASPA routine, so that isn't even a need to return the scope to the home position to commence the second alignment.
However, achieving a very good PA via the ASPA routine requires 2 iterations of the PA routine, and yes, each PA is followed by an alignment.
(So, I added more effort than I reduced, however achieving a very good PA is required for AP.  (That and usually more :-)
#4 Seeker999
Seeker999
Posted 24 February 2021 - 09:54 AM
Yes, unfortunately I have a poor view of the sky, so I can't do an Auto Align with the StarSense but I do have a good view of the ecliptic.
I live in the southern hemisphere and I don't have a clear view of the south celestial pole either.
