What do you use?
I don't like the case it was delivered in. Too tight of a fit when I place the scope in it, one of the latches is way too rigid(I fear I may break it by applying excessive force) and not sure about those handheld straps which are supposed to be used to lower/remove it from the case. Since I don't have a permanent setup I don't relish the idea of having to use that case. If you are using non AP supplied case would like to hear from you.
Aside from that when I took it out of the case was surprised to see three or four fine specks of 'dust' already on the inner element . My OCD brain won't let me look past it *sigh* (first world problem). Does it matter if it already has some fine 'dust' specks ?
Edited by indio, 23 February 2021 - 03:27 PM.
