New to me LX200GPS
#1
Posted 23 February 2021 - 03:58 PM
#2
Posted 23 February 2021 - 04:11 PM
Hi I cannot see of being of any issue to be honest according to Meades website the latest version is 4.2 if it works ok then best left alone I think I would definitely reboot the handset tho to factory settings,calibrate the motors,drive training as might not of been used for a while.
#3
Posted 23 February 2021 - 04:13 PM
#4
Posted 23 February 2021 - 04:26 PM
Gday Maineiac78
Just let it get a GPS fix and see if it reports the correct date.
If not, you will need to upgrade the firmware or turn the GPS OFF
and manually enter date/time each time you turn it on.
If you do choose to upgrade, i suggest you ignore Meades updater
and use the freeware "StarPatch" app to load the patched 4.2g firmeware.
It is the most robust firmware version currently available for the LX200GPS.
#5
Posted 23 February 2021 - 04:30 PM
#6
Posted 23 February 2021 - 04:31 PM
#7
Posted 23 February 2021 - 04:41 PM
I had an LX200 GPS and used it with a software version which was one down from the current, it worked fine so I figured if it ain’t broke don’t fix it cause we know what happens when software issues rear ugly heads.
#8
Posted 23 February 2021 - 04:47 PM
#9
Posted 23 February 2021 - 05:05 PM
Gday Maineiac78
To connect/upgrade the mount, you need a properly wired cable.
It is defined as a "Meade 507" cable, but can be made easily if you have the tools.
You need a real COM port, or a suitable USBtoserial ( note true rs232 not TTL ) converter
and then the 507 wired plug.
If you have no cables at all, there are several sites now that sell very slimline
fully integrated units,
ie https://www.ebay.com...R-/393052697852
but if you already have a working USB2rs232 converter, making a connection cable is easy.
( Just google "meade 507 cable pinout" )
If you need to buy a converter, it pays to get an FTDI based unit as they have the better drivers.
#10
Posted 23 February 2021 - 05:29 PM
#11
Posted 23 February 2021 - 05:34 PM
Gday Maineiac78
maybe I'll at least check out using scope under pc control!
You can use my PEC editor to look at a lot of the data in the mount if you want.
http://members.optus...om.au/johansea/
Your firmware is too early to allow a lot of the newer remote handbox commands to operate
but the basics for slewing etc should work.
As to updating, its a painless operation, and if anything does go wrong,
there is a protected safeload mode that can be used to restore a damaged firmware load..
#12
Posted 23 February 2021 - 05:37 PM
#13
Posted 23 February 2021 - 05:45 PM
Gday Maineiac78
Yep, theres a lot there if starting from scratch.
If you have done a basic align etc already, then it would appear the "mechanicals" work
but there were a lot of bugs over the years and a lot of enhancements.
If you want to use PC control at some time, i suggest updating the firmware
will need to be done.
If you just want to runbberneck for a while, you can leave it as is
and the "basic" remote control should stil work.
#14
Posted 23 February 2021 - 06:03 PM
#15
Posted 27 February 2021 - 12:50 PM
Well, I ordered the USB cable with built in adapter. Installed drivers for it, and are now up and running! I did the starpatch to version 4.2g but will need to wait till nicer weather to bring outside and see if it finds GPS. I also replaced the cr2032 battery on the board, so hopefully that helps hold the date/time. For some reason it seems to be 1 day off every time i power up. I also followed the link to that PEC editor, and was able to use commands through PC control. My next project will to see if I can control scope via a program like Stellarium or something similar. Thanks again for all the support and info!
#16
Posted 27 February 2021 - 03:43 PM
Gday Maineiac78
Excellent
If it doesnt get a GPS fix, it will default ti the last date it was used and 8:00PM
until you override it.
Have fun.
You might also want to look up and install the ASCOM platform.
That is a program/system that allows all sorts of different software programs to connect to your mount using a standard interface.
You need to load the ASCOM platform first, then a Meade specific driver, and after that, any ASCOM compatible app can connect.
#17
Posted 27 February 2021 - 06:08 PM
Edited by Maineiac78, 27 February 2021 - 06:26 PM.
#18
Posted 27 February 2021 - 06:35 PM
Gday Maineiac78
The scope has a factory microfocuser on it as well, would you know if that can still be in place if I got a video camera eyepiece as well?
Cant see why not. Just get the right adapters and you can do just about anything.
#19
Posted 28 February 2021 - 06:16 PM
- carolinaskies likes this
