ASIAIR Wifi Issue
#1
Posted 25 February 2021 - 10:49 AM
The network will show up on my devices when I scan, ill connect as usual, but when I open the app it states there is no asiair available to connect to.
At a loss here and desperately wanting to find a solution as this will be my last free night for quite some time.
Thanks in advance.
#2
Posted 25 February 2021 - 11:59 AM
Can you try the hardwired ethernet connection? Maybe that will get you going long enough to use the free night, and you can do more extensive debug later. The only other thing I can think of is to flash a new SD card from a backup to see if that changes the behavior.
Also - you might try the Facebook ASIAir group, maybe some ideas there.
Edited by MJB, 25 February 2021 - 12:01 PM.
#3
Posted 25 February 2021 - 12:50 PM
#4
Posted 25 February 2021 - 01:24 PM
Yeah, it's a boot image - it's got the license file and other stuff. I doubt an original ASIAir one would work. I'd recommend popping out the SD card and making a backup now just in case.
#5
Posted 25 February 2021 - 01:31 PM
Moving this topic from EAA to Astronomy Software & Computers for a better fit.
- EstvanK3 likes this
#6
Posted 25 February 2021 - 02:02 PM
One more thing - check that there is not a stronger signal overriding the ASIAir. On the device that is running the app, maybe tell it to ignore other previously connected networks. The wifi is a known weak point on the ASIAir. Get right up next to it. I've had a signal drop within 5 feet of the mount, so try different positions. If it shows up as you say, then it must be broadcasting, right? I'd take that as a good sign.
#7
Posted 25 February 2021 - 02:46 PM
#8
It’s likely a corrupted system file.
Without a back-up, you’ll have to get in touch with ZWO for a new license file.
if you had a back-up, you could test the new system file, and if wi-fi still didn’t work, it would point to a hardware problem.
#9
Posted 25 February 2021 - 09:00 PM
- MJB likes this
#10
Posted 27 February 2021 - 09:27 PM
- adamsdp likes this
#11
Posted 05 March 2021 - 07:44 AM
I just posted a solution to this issue here on CN. https://www.cloudyni...mma/?hl=+asiair
