Everything seems to come with one of these! Not necessarily a problem, since they often function as part of the dust cover for whatever they came with in conjunction with a 1.25" plug, and it's nice to always haven them handy when you need them. Still though, I'm at 5 and counting, and I don't own anywhere near as much gear as some of you.
How many 2" to 1.25" eyepiece adapters do you own?
#1
Posted 25 February 2021 - 01:59 PM
#2
Posted 25 February 2021 - 02:04 PM
I think 4.
#3
Posted 25 February 2021 - 02:09 PM
For each of my two telescopes, I have one Clicklock adapter and one Televue Equalizer.
#5
Posted 25 February 2021 - 02:18 PM
to many
#6
Posted 25 February 2021 - 02:24 PM
just one...
#7
Posted 25 February 2021 - 02:28 PM
Having several scopes, I also have several size eyepieces - not just .965, but several different size microscope eyepieces, plus the odd size ones, so I ended up making an adapter for each one, figuring why keep pulling the eyepiece out and putting a different one in, just go ahead and make one for each. So I bought a box of 18 adapters here on Cloudy Nights, plus a few more here and there, so a lot.
- RobertMaples likes this
#8
Posted 25 February 2021 - 06:14 PM
Not enough! I was looking over my kit today just hoping for a chance to set up my XT for some viewing and upon inspecting my focus travel and cleanliness (after a long life in the closet), noticed my 2"-1.25 is slightly " Out of round" when chucking a sight tube in it, it wiggled a tad
. I suppose I could use the RC's adapter, it is a compression type but it is taller than the factory version. Guess I'll check classifieds
! ( Not enough in focus for direct threading the G3)
CS! Ralph
#9
Posted 25 February 2021 - 06:25 PM
I use two.
One has the 1.25" hole sit above the level of the 2" part. The other has the 1.25" hole recessed so that it sits just below the 2" hole. This allows some eyepieces to be used in scopes that have limited draw-tube travel, and having a little more "in" travel makes just enough of a difference in being able to focus with some eyepieces or not. My default adapter is the first one mentioned.
Alex.
#10
Posted 25 February 2021 - 06:36 PM
Two.
One with my 8" newt and one with the diagonal I bought to use with the mak that still hasn't arrived.
I'd like to use the one from the diagonal on the newt because it has filter threads and compression ring, but it doesn't fit very well in the newts focuser. Wouldn't mind having a better one to use with the newt.
#11
Posted 25 February 2021 - 10:45 PM
I currently have four, but I actually plan on getting a few more. I want to have one for each 1-1/4" eyepiece that I regularly use in any telescope that has a 2" focuser. That way I can switch between 1-1/4" and 2" eyepieces without having to worry about the adapter - I would just switch the eyepiece/adapter combinations out like they were 2" eyepieces.
#12
Posted 25 February 2021 - 11:03 PM
I have 3, but typically only use two of them.
#13
Posted 25 February 2021 - 11:15 PM
I have 6 for four refractors and two 2" diagonals. I may have one more in the C11. (not going to look)
AP 2" Visual Back threads onto the 3.25" rear cell of the Celestron 11 I think I put one in there.
#14
Posted 26 February 2021 - 07:50 AM
6 or 7, I think....
#16
Posted 26 February 2021 - 08:34 AM
Same
#17
Posted 26 February 2021 - 10:33 AM
I have about 4 or 5, I think.
Am I the only one who is annoyed by the fact that they are not a universal design and therefore not easily interchangeable? I especially don't like the ones where the location of the set screw prevents you from inserting the adapter all the way into the focuser.
#18
Posted 26 February 2021 - 01:06 PM
2. One came with the Dob, one came with the laser collimator.
Edited by Borodog, 26 February 2021 - 01:06 PM.
#19
Posted 26 February 2021 - 02:00 PM
I just have one, and I never use it.
- ram812 likes this
#20
Posted 26 February 2021 - 07:29 PM
In my experience, the vast majority are interchangeable... sometimes a longer set screw can be useful..
Posted 26 February 2021 - 07:31 PM
Maybe 4.5?
Having a 2" diagonal on my LX200 Classic, I use maybe 3.5 at every visual session:
#1 - The it-came-with-the-LX Meade adapter lives on attached to my Orion reticle and used to align the GoTo's brain;
#2 - Bought a used Astrotech diagonal, it's adapter takes care of my Celestron/Baader Micro Guide and is used to fine tune the above alignment;
#3 - Now have a TV Everbright diagonal, it's adapter takes care of my TV Delos 10mm;
#4 - is a glow-in-the-dark NiteEye's adapter that I use as a paperweight;
and the .5? - Does the cylinder that makes a TV Ethos 6mm work in both 2" and 1ΒΌ" count as an adapter?
#22
Posted 26 February 2021 - 07:47 PM
I have 4 in my accessory box. And several more installed in my telescopes (that I did not bother to check). I like the WO Rotolocks and tend to only use them these days.
#23
Posted 26 February 2021 - 07:53 PM
After selling a few, I have only two now. One is a precision centering adapter...
#24
Posted 27 February 2021 - 05:50 PM
About 5 - a pair of rotolock ones and the rest have compression rings and a screw...
#25
Posted 28 February 2021 - 05:15 AM
I wish that I could count that high. They breed in my junk box.
