Does anyone know is Cem26 and AsiAir 2 working together ?
Posted 26 February 2021 - 08:50 AM
Posted 26 February 2021 - 11:20 AM
I would think so. My CEM60 has passed initial dry-run tests without any troubleshooting (although the ASI120mm mini sure as hades didn't <grumble>)
Edited by doole, 26 February 2021 - 11:23 AM.
Posted 26 February 2021 - 02:16 PM
Looks like the CEM26 comes with the new Go2Nova 8409 controller.
You would need to find out from ZWO if the AsiAir has the correct driver. (do they use INDI drivers, or their own?)
I found this much about ASCOM drivers:
https://www.ioptron....cles.asp?ID=325
This ASCOM Driver and iOptron Commander uses RS232 command language 2014 V3.x
Updated 12/14/2020
Mounts supported:
CEM120
CEM70
CEM26
GEM28
Posted 26 February 2021 - 07:23 PM
My GEM 45(2021) Works perfectly with ASI air pro. I connect my mount directly to ASI air pro. I think you will have to connect it through the hand controller if I’m not mistaken. But it should work perfectly.
Posted 27 February 2021 - 05:18 AM
Thank you all!
I hope it will work.... because the new USB thing.....
![]() Cloudy Nights LLC Cloudy Nights Sponsor: Astronomics |
