Plate Solve issues with L-eXtreme and ASIAir Pro
Polar Alignment
7 replies to this topic
#1 djr5899
djr5899
  • Loc: Florida
Posted 26 February 2021 - 11:16 PM
I purchased an L-eXtreme filter about a week ago, and tonight was my first attempt in using it with imaging.  Unfortunately, I didn't get very far.  I use an ASIAir Pro with my rig, and I was unable to plate solve and polar align.  While there was some very light low level clouds (rated a 2 on Clear Outside), I could clearly see Polaris with the naked eye.  Once focused, I did notice that I did not see as many stars in the field of view.
When I went to do the plate solving for PA, it was only finding between 20-50 stars, and sometimes below.  In the past, plate solving typically finds between 80-150 stars during the first step of PA.  Once or twice it was able to plate solve, but when the ASIAir did it's 60 degree RA movement, it could never plate solve once moved.
I have a WO ZS 73II scope with a field flattener on it, and the WO recommendation is to screw the filter onto the back of the field flattener.  If I cannot see enough stars to plate solve with this setup, I was wondering if I would need to get a filter drawer, and add the filter after plate solving...and if that would mess anything up since the WO recommendation is attaching it to the flattener.
Anyone else have a similar experience with an L-eXtreme and ASIAir Pro, where it cannot see enough stars to properly plate solve?  If so, how did you resolve it?
#2 wxcloud
wxcloud
  • Loc: Denver, Co
Posted 26 February 2021 - 11:21 PM
Is there a way to increase the exposure time, say to like 5 seconds instead of 1? Not sure what the default exposure time is on the asiair? If possible to increase it some, that's what I'd try.
  • djr5899 likes this
#3 djr5899
djr5899
  • Loc: Florida
Posted 26 February 2021 - 11:29 PM
Good idea.  I've never messed with these settings and it always just worked.  I'd usually use half second exposures for focusing while using the fine adjustment knob on my scope to get dialed in, and then continued to the PA menu to do the plate solve.  If it doesn't have a default and picks up the half second from focusing, that could definitely be an issue.
I just checked the manual for the ASIAir Pro, and it says they recommend 1-2s exposures, and setting binning to 4.  Will have to pull the gear out tomorrow inside the house and see if I can test this setting out.
Thanks for the tip.  An extra, non-frustrated brain and set of eyes is usually a good help!
#4 Jim Waters
Jim Waters
  • Loc: Phoenix, AZ USA
Posted 26 February 2021 - 11:39 PM
With the L-eXtreme you may need 10 sec because of the light loss.
#5 FRANKVSTAR
FRANKVSTAR
  • Loc: GASTON S.C
Posted 26 February 2021 - 11:44 PM
He is right about exposure times. I was using  scope with Sharp Cap to plate solve and PA. I got only 5 to 8 stars. Thought about it for a while and then I figured out how to get longer exposures at 4 to 6 seconds from 1sec and suddenly I saw up to 20 or more stars. Had to wait longer for each image shot to be plate solved, but no much and it works now.
#6 Wei
Wei
  • Loc: SF East Bay
Posted 27 February 2021 - 01:26 AM
3-5 sec should be fine. You can test it out.  If you still have trouble, maybe check if there are visual obstruction smile.gif
Plate solve don't work when pointing towards polaris.
Edited by Wei, 27 February 2021 - 01:28 AM.
  • Neil_Phan likes this
#7 Neil_Phan
Neil_Phan
Posted 27 February 2021 - 01:32 AM
Plate solve don't work when pointing towards polaris.[/quote]
Yes it does. My rig does plate solving polar alignment using ASIAIR at Polaris in about 3 seconds
#8 base16
base16
  • Loc: North California
Posted 27 February 2021 - 01:38 AM
I dont use filters anymore but when I previously used this exact filter, I had to increase exposure. You can different exposures for Polar Alignment, Focus, Preview and of course live stacking.
Also tagged with one or more of these keywords: Polar Alignment
