Starsense and dew
4 replies to this topic
#1 scuba561
scuba561
Posted 27 February 2021 - 12:55 PM
Just received my Nexstar SE8.  Yeah!  Having some issues getting autoalign to work, but I think I will be able to work through the issues.  Right now I am in an urban area with a lot of light, trees, and houses.
My question is this.  Do I need to autoalign every time I setup the scope?  i.e. I use the scope for a few hours in my front yard.  Carry the scope in the house when done.  Next night bring the scope back to front yard and set it up.  I ASSume I need to autoalign sense the scope does not know if I put it in the same place, facing the same direction?  Correct?
Also, last night the front of the OTA was completely covered with dew.  I read about cutting a section from a sleeping bad pad and making a shield on the front of the tube.  Would an old yoga matt work just as well?  Does the material of the shield make a difference?
Thanks for your wisdom!
#2 Spitty
Spitty
Posted 27 February 2021 - 01:03 PM
Following with interest regarding the auto alignment.
#3 Gamewarden
Gamewarden
  • Loc: Centreville, Ontario, Canada
Posted 27 February 2021 - 01:04 PM
Yes you must re align everytime you move the scope. I found auto 2 align to be the quickest and most accurate. These scopes generally need a dew shield unless you live in Arizona. You can make your own I would expect black is better than any light colour as it helps with local light pollution also if you have that problem.
  • Hexley likes this
#4 Dynan
Dynan
  • Loc: NOLA
Posted 27 February 2021 - 01:37 PM
Yes, redo SS AutoAlign if you've moved the scopa even an inch. It's a GREAT addition to an 8SE, but it's not magic .lol.gif It was the best addition I made to my 8SE and used it on my Celestron CGX with wonderful results.
Depending on your local weather (humidity/dew point) you will probably need to use a dew heater strap along with a dew shield.
#5 audioengr
audioengr
Posted 28 February 2021 - 07:40 PM
Auto align is required each time.  Get a dew shield and maybe a heated one or a heated strap and you will not have any dew at any temperature.
  • Dynan likes this
