Starlink? Asteroids? Space Junk? What did I capture
10 replies to this topic
#1 Voska
Voska
  • Loc: Beach Park, IL, USA
Posted 27 February 2021 - 04:57 PM
Ok so my initial thought is this was a starlink train... BUT I have captured a starlink train before and it did NOT look like this.
https://drive.google...iew?usp=sharing
That is the link to the video file i created using PixInsight.
things to note here... this is with a WO RedCat51 with an ASI 294MM
there are 4 total frames.
each frame was 5 MINUTES long so a total of 20 minutes for these objects to pass by
this is my green filter imaging the Horsehead/Flame nebula
2021-01-22 @ 21:50 - 22:07 PM CST (Chicago area)
any thoughts?
Edited by Voska, 27 February 2021 - 05:12 PM.
#2 Cali
Cali
  • Loc: Bay Area
Posted 27 February 2021 - 05:16 PM
Looks like Starlink to me.
- Cal
#3 GregsCNAccount
GregsCNAccount
Posted 27 February 2021 - 05:18 PM
If the objects were moving at a constant speed through your field of view, I would expect them to be elongated streaks in each 5 minute image.  Instead you have a line of dots that jump in position from one frame to the next.  Are you sure you didn't have four short exposures that were spaced 5 minutes apart?
#4 Voska
Voska
Posted 27 February 2021 - 05:42 PM
all images were taken at 300 second exposures. I have other images from that night of a plane as well as a few satellites crossing the image all streaking and going different ways. I am 99.9% confident these exposures were 5 mins each
#5 ravenhawk82
ravenhawk82
Posted 27 February 2021 - 05:49 PM
If the exposures were 5 minutes, that was likely a plane going overhead. The nav lights will blink, so you'll get a series of dots in your long exposure instead of a solid streak. The only other way you'd get that output from a 5 minute exposure is if there were multiple objects hanging perfectly still in a line. Barring an impending alien invasion, this seems unlikely ;) My guess is a plane.
Also, at the focal length you're at, you'd only see one or maybe two Starlink satellites in the frame at a time. Seeing so many dots close together like this makes me think it's one object blinking across the sky.
#6 Voska
Voska
Posted 27 February 2021 - 06:11 PM
for reference here are some images which show a plane, and two different satellites
Plane
Plane
Satellite 1
Satellite 1
Satellite 2
Satellite 2
#7 GregsCNAccount
GregsCNAccount
Posted 27 February 2021 - 06:37 PM
In frame 2 I count 14 dots and in frame 3 I count 13.  With 300 second frames that makes the period that the object would have to flash at to be in the the range of about 21-23 seconds.  That's way too slow for an aircraft strobe.  I have observed tumbling satellites that flash brightly once per revolution.  Perhaps that's what this is.
#8 Voska
Voska
Posted 27 February 2021 - 07:10 PM
I was kind of thinking something like this or space debris. but again with it being over 10 minutes (assuming it came into the image at the end of 1 image and was leaving at the beginning of the 4th image) to cross the field of view. how slow/high of orbit would it have to be to do that? are there any sources i can use to make look up and see what satellites might have passed by the target on that night?
I see in Stellarium that at 22:17  the MUOS-1 satellite passes just in a corner of the frame, but wrong time and wrong location for this particular object in the video.
#9 Phishin_phool
Phishin_phool
  • Loc: Ohio
Posted 27 February 2021 - 07:34 PM
It is probably one of these:
http://stuffin.space/
#10 lkannard
lkannard
Posted 28 February 2021 - 08:46 PM
Starlink is the scourge of Astronomy.
We really need a James Bond Laser to blast them out of orbit.
  • acommonsoul likes this
#11 lkannard
lkannard
