Antlia Pro 3nm Filter Halo Comparison
41 replies to this topic
#26 Jack2338
Jack2338
  • Loc: Silicon Valley
Posted 05 April 2021 - 01:25 AM
Here's an update.  The dealer was nice enough to reverse the 3nm Oiii Antlia Pro filter in the 2" cell.  The results are much better with the coated shiny surface facing the sky away from the camera.  The halo is still there, but greatly reduced.  Therefore, try reversing the filter direction if you are getting severe halos.  The test star was Sirius, and the exposure was at 95% of saturation at the star center. One image is calibrated but no stretch.  The other image is stretched to show the residual halo.
#27 Cfreerksen
Cfreerksen
  • Loc: Tooele, Ut
Posted 05 April 2021 - 10:15 PM
Here are some tests on the filters I just installed. Can't say that I am happy. Has anyone seen the ray artifact that I am getting on the SII? The halo on the Ha doesn't look good either.
The star selected is Eta Geminorum a magnitude 3.3 near the Jelly fish Nebula IC443.
All single frames w/ ASI2600MM and WO GT102 w/.72 reducer. Soft Stretched. Antlia filters 3nm.
Chris
As far as the OIII, not too shabby.
I also have a strange artifact on the Red filter. Any ideas?
Chris
To update: The Antlia filters are going back to the vendor. Threw down on a set of Chroma but went on the cheap with 5nm. I have to say the improvement is dramatic. So was the price difference, about double. But the shipping was fast about 10 days from order to door.
Chris
#28 AnakChan
AnakChan
  • Loc: Oz
Posted 06 April 2021 - 03:12 AM
My heart's sinking. I've just paid for a set of Antlia full set 50mm round unmounted. The Oiii is meant to be the latest revision but am surprised to hear about the Sii and R as that shouldn't be the case. Another forum member had an issue with his R which AFAIK was replaced.
Edited by AnakChan, 06 April 2021 - 03:13 AM.
#29 Cfreerksen
Cfreerksen
  • Loc: Tooele, Ut
Posted 07 April 2021 - 09:31 AM
The ray SII pattern disappeared after a cleaning and of course position change (rotation). Not sure what was the issue. The moire pattern on the red is not the filter. I have seen this now (last night) on the Chroma and a very bright star in red. looking into that, camera window maybe? So the result is the OIII seemed to be fine with a fair to minor halo. The SII and Ha showed strong halos. This perplexed me as the complaints I have seen were all about the OIII having strong halo. All the filters showed very good contrast and excellent detail.
Antlia and the vendor were fairly responsive. Their assessment was reflections from the reducer were the cause. I would tend to agree with the halos being off-center and directionally dependent on the position around the center of the image. Your setup may be more forgiving. Mine was with a .72 WO Flat8 reducer on a GT102 @ f5.
I originally purchased because they were reviewed well but in the end not up to the quality I was expecting. I would say you get what you pay for.
Chris
Edited by Cfreerksen, 07 April 2021 - 09:40 AM.
#30 AnakChan
AnakChan
  • Loc: Oz
Posted 08 April 2021 - 03:53 AM
Chris this from post #18, it looks like Antlia is talking about this reflection circled in red (i.e. the reflection bouncing back 'n forth between the outward facing side of the filter back to the reducer, then bouncing back in toward the sensor)? I guess that'll depend on how far that reducer glass is away from the filter 'cos if it's pretty far away I'd guess that light to be quite diffused and wouldn't be such a strong halo. But if it's close to the filter, then maybe it could result in a strong halo? Just found on CyclopsOptics that the backfocus for the Flat8 for the 102 is 12.1mm.
There's another thread here which as been extremely useful. @sharkmelley's probably the best to comment as he's the expert on this.
Anyhow, I should get my Antlia filters before month end so will get a chance to play with it myself.
Edited by AnakChan, 08 April 2021 - 04:03 AM.
#31 Sponge
Sponge
Posted 08 April 2021 - 04:38 AM
Chris
This is almost certainly a halo caused by an internal filter reflection. I had a similar issue with my Antlia 3nm Ha Pro and returned it for a different sample which did not exhibit the same issue.
If you could measure the size of your halos in pixels, and state the pixel size of your camera then we can calculate the reflection path length easily.
The reflection path distance can be derived using the formula d=t/(nF), where:
d = size of halo;
t = reflection path distance;
n = refractive index; and
F = focal ratio
Substituting in values for your system and assuming n=1.5 for glass, the size of the halo (if the 2mm thick filter is the culprit) should be ~266um.
#32 lakerunr
lakerunr
  • Loc: WI
Posted 15 April 2021 - 07:25 PM
I bought a set of Antlia 36mm LRGB and 3nm SHO. Nice packaging, mediocre product. The Green filter in the LRGB set had the center totally messed up. Like no coating in center. Made LRGB imaging useless. SHOs had halos on bright stars, not as bad as earlier 3.5nm Antlias, as seen on forums here, but a lot more than my set of 31mm 5nm Astrodons, or 31mm 3nm Chromas.
Sent them back. Bought 36mm Astrodons, LRGB and 5nm SHO to keep price down a bit. No problems.
I checked them with ASI183MM and ASI294MM, where I had the 31mm sets. I initially had them on my ASI2600MM, which is what I bought them for because 31mm filters gave too much vignetting.
Anyway, that was my first and last experience with Antlias. Good luck!
Edited by lakerunr, 15 April 2021 - 07:28 PM.
  • leviathan and AstroCatinfo like this
#33 DennisOrion
DennisOrion
  • Loc: Orange County, CA
Posted 15 April 2021 - 10:16 PM
I was looking into a full set (7) of the Antlia 36mm filters. I actually have the SII already and I'm waiting for the Ha and OIII to come in stock. I still haven't seen the LRGB Pro set listed. With the unknown delivery of the rest of the filters I need and the issues pointed out in this thread, I'll look for other options, like the Chroma's: The LRGB set will be a little more than the Antlia's, no big deal. It's the narrowband filters:
3nm are $775
5nm are $620
8nm are $355
The Antlia narrowband filters are $360, $330 and $330, so close to the Chroma 8nm. I know narrower should be better, but I have no idea what the performance difference would be between 3, 5 and 8nm filters. In other words Antlia 3nm or Chroma 8nm? Will I regret going with 8nm filters? Any suggestions?
Dennis
  • AstroCatinfo likes this
#34 AnakChan
AnakChan
  • Loc: Oz
Posted 16 April 2021 - 12:24 AM
Do you have any pictures of :-
1) the filters
2) the results you got
that you're able to share please? I'm really surprised to hear that and news such as this worries me as I have paid and am waiting for my Antlia filters.
#35 RJF-Astro
RJF-Astro
  • Loc: Zeist, Netherlands
Posted 16 April 2021 - 01:31 AM
3nm are $775
5nm are $620
8nm are $355
Dennis
In my experience, moving from 7-8nm Baader filters to 3nm Chroma, the difference is significant. My narrowband images keep surprising me since I got the Chroma, especially Ha which I really like to do in B/W.
Halo's did bother me with the Baader too. Some targets were just not possible to image, like the Horsehead, Y-cas and IC443 Jellyfish, others gave slight halo's but not too bad. That problem went away with Chroma, no issues whatsoever.
So yea, tough call. Actually I'd save up for 5nm Chroma at least if narrowband is your priority. It is a good investment.
#36 AstroCatinfo
AstroCatinfo
  • Loc: Prades, Catalunya - Spain
Posted 16 April 2021 - 07:13 AM
Very useful Larry. I also ordered LRGB 36mm Astrodon for my ASI2600MM. But also asked for a 3nm Ha ANTLIA... now you make me hesitate if I should go the 5nm SHO Astrodon direction. 3nm SHO Astrodon are too expensive...
  • lakerunr likes this
#37 DennisOrion
DennisOrion
Posted 16 April 2021 - 08:12 AM
What about the Astrodon 5nm filters vs. the Chroma 5nm?  I see they are $501 each, but I have no idea of availability.
#38 RJF-Astro
RJF-Astro
Posted 16 April 2021 - 08:46 AM
Yes, another combination you often see is 5nm Ha and 3nm O3 and S2. Because Ha is so abundant and you also pick up the signal from nitrogen. And when you image Ha from galaxies, redshift is less of an issue.
I don't know about Astrodon and Chroma. They seem to be on par. There were some reports on packaging and service issues with Astrodon here on CN, but I have no idea if this has been solved and how often that happens. Reports on Chroma have been mostly positive.
Edited by RJF-Astro, 16 April 2021 - 08:47 AM.
  • PhotonHunter1 likes this
#39 lakerunr
lakerunr
  • Loc: WI
Posted 16 April 2021 - 08:54 AM
When I bought the 36mm Astrodons, they were in stock at Farpoint, took a week to get. Ordered them 3/5/2021.
I have a 31mm set of 3nm Chroma SHO, and 31mm set of Astrodon with 5nm Ha and SII, and 3nm OIII. Honestly, I have not seen that big of a difference between 5nm and 3nm in those. I guess the 3nms are a bit more useful during bright moon phase, if the target is closer to the moon. I have not really had a chance to compare the 36mm Astrodon OIII 5nm to the 31mm 3nm versions. Not that many narrowband targets at 42 degrees N right now. :)
#40 PhotonHunter1
PhotonHunter1
  • Loc: Northwest Suburbs of Chicago
Posted 16 April 2021 - 10:45 AM
Thanks for this information RJF! This answers a question I was getting ready to ask.
  • AstroCatinfo and RJF-Astro like this
#41 RJF-Astro
RJF-Astro
Posted 16 April 2021 - 11:25 AM
If the redshift is a consideration, this list might be interesting. It shows most common galaxies to image with the amount of redshift and if a 3nm is still usable. I made it a while back because I did get the 3nm. It turns out most of the popular targets like M82, M101 etc are fine. But with the Leo Triplet the Ha-signal drops for instance. Maybe I will get like a 12nm filter in the future, but for now there is still plenty to photograph.
  • PhotonHunter1 and AstroCatinfo like this
#42 PhotonHunter1
PhotonHunter1
Posted 17 April 2021 - 07:56 PM
Looking at the Chroma site, it appears the 5nm filter will capture the Ha in most if not all the galaxies you've listed. Would you agree?
