Has anyone else had a problem reading files created by ASIair Pro in Live mode with AstroImageJ (AIJ)?
I'm trying to learn AIJ and want to use some files I have captured but keep getting the following error. I do not get the error when loading sample files provided by AIJ and others I've found online.
java.lang.NumberFormatException: For input string: "1036."
at java.lang.NumberFormatException.forInputString(NumberFormatException.java:65)
at java.lang.Integer.parseInt(Integer.java:580)
at java.lang.Integer.parseInt(Integer.java:615)
at astroj.FitsJ.getCardIntValue(FitsJ.java:1160)
at astroj.WCS.process(WCS.java:224)
at astroj.WCS.<init>(WCS.java:144)
at astroj.AstroStackWindow.<init>(AstroStackWindow.java:580)
at Astronomy_Listener.imageOpened(Astronomy_Listener.java:46)
at ij.ImagePlus.notifyListeners(ImagePlus.java:2112)
at ij.ImagePlus.show(ImagePlus.java:403)
at ij.ImagePlus.show(ImagePlus.java:349)
at ij.plugin.FolderOpener.run(FolderOpener.java:331)
at ij.IJ.runPlugIn(IJ.java:159)
at ij.Executer.runCommand(Executer.java:127)
at ij.Executer.run(Executer.java:64)
at java.lang.Thread.run(Thread.java:748)
