How would i go about adding a second finder?
10 replies to this topic
#1 Pokemoncrusher1
Pokemoncrusher1
Posted 01 March 2021 - 02:46 PM
If I already have the included dovetial and rdf and wanted to add a finderscope how would i mount it? im guessing id need to drill holes?
#2 MikiSJ
MikiSJ
  • Loc: San Jose, CA
Posted 01 March 2021 - 02:56 PM
Maybe something like this:
https://www.ebay.com/itm/254852503880
  • Jon Isaacs, deepwoods1 and vdog like this
#3 deepwoods1
deepwoods1
  • Loc: Connecticut
Posted 01 March 2021 - 03:03 PM
This will accommodate two finders.
https://www.telescop...rd=Finder mount
#4 vdog
vdog
  • Loc: California Central Valley, U.S.A.
I used to have a Z130.  I added a 6x30 RA finder in between the RDF and focuser by drilling a couple of small holes.  You can use a double (or triple) bracket but that adds more weight and you may end up needing counterweights.
Edited by vdog, 01 March 2021 - 03:04 PM.
#5 eyeoftexas
eyeoftexas
Posted 01 March 2021 - 03:12 PM
You can either have the dual finder shoes at angles, like in posts #2 and #3, or straight across like this:
http://scopestuff.com/ss_dfmb.htm
I use this one from Scopestuff because I have a Telrad on it.
#6 spaceoddity
spaceoddity
  • Loc: Cloudsylvania
Posted 01 March 2021 - 05:07 PM
Telrad's, rigel quickfinder and I believe most RDF's are attached by double sided tape. A finder scope requires a mounting shoe that must be screwed fast to the OTA which will require some holes to be drilled.
#7 SloMoe
SloMoe
  • Loc: Washington State
Posted 01 March 2021 - 07:55 PM
here ya go, 3D printed, light weight strong,
https://jwbozeman.co...ovetail-adapter
#8 dark_night
dark_night
  • Loc: Bangalore, India
Posted 01 March 2021 - 08:24 PM
Have a look at this thread - https://www.cloudyni...ng-rdf-to-raci/
You can mount the optical tube on the dovetail base andd RDf is pretty light and you can use double sided padded sticky pads and a nylon tie to mount RDF on the optical finder mount.
#9 MaknMe
MaknMe
Posted 01 March 2021 - 08:37 PM
I just use duct tape to attach my Telrads (I have 2) to both my CPC 800 and Meade NG 125. This leaves the finder shoes free on my both scopes.
#10 Pokemoncrusher1
Pokemoncrusher1
Posted 01 March 2021 - 09:43 PM
Thanks everyone, will probably just put the optical on the bracker and the rdf with strong tape or soemthing of the like, if not will look into the dual bracket option
#11 NYJohn S
NYJohn S
  • Loc: Northport, NY
Posted 02 March 2021 - 09:26 AM
I have 2 XT8's, one has the dual bracket with a 9x50 & Telrad. On the other one I just mounted a small RDF on the 9x50 bracket with 2 sided tape. I actual prefer that setup. It's lighter so it doesn't throw the balance of the scope off and I don't worry about hitting the finder when carrying it through a doorway. I usually remove the dual bracket with the Telrad because it sticks out so far. Part of the issue is the large size of the Telrad.
Edited by NYJohn S, 02 March 2021 - 09:27 AM.
