The Baader 2" safety cool Herschel Prism
7 replies to this topic
#1 Jethro7
Jethro7
  • Loc: N.W. Florida
Posted 03 March 2021 - 12:59 AM
Hello Cners,
I am not new to the hobby, but will be new to Solar observing and would like opinions on using a Baader 2" safety cool Hercshel  prism diagonal. Besides using this diagonal is there anything else that I need to know?  I will be using this either with a AT102ED or a Altair 102ED F/11.
THANK YOU AND KEEP LOOKING UP Jethro
  • philmor56 likes this
#2 noisejammer
noisejammer
    Fish Slapper
  • Loc: The Uncanny Valley
Posted 03 March 2021 - 01:59 AM
The only crucial point is that you use either a neutral density, a rotatable polariser or a solar continuum filter after the prism. I find the solar continuum filter (540nm) gives the most detailed view but the image is bright yellow-green.
Herschel wedges can be used with refractors only. I use mine with a TOA150.
I have used my Tak 1.6x extender before the prism without difficulty. This is probably not recommended but I locate it well inside focus (roughly 8") so the illumination is not too extreme. I have had no issues.
You may want to get yourself a solar finder. I find the Televue Sol-Searcher works quite well. You can also try the ScopeStuff offering - I have an older version which I secure using a bit of bungee cord.
  • briansalomon1 and Jethro7 like this
#3 sg6
sg6
  • Loc: Norfolk, UK.
Posted 03 March 2021 - 02:24 AM
The wedge will have to have an ND3 filter installed - not a case of either/or. You have to have one.
Will say I would expect the Baader to have a permanent one installed - giving you no choice or option but keeping your eye safe.
After the wedge you can put in a variable polarizer if you wanted to reduce the intensity down more - it would be at around 1/20,000 of the incoming at this stage. 1/20 for the wedge and 1/1000 for the ND3. An ND5 front filter is 1/100,000 so the wedge and its filter is some 5x more then a Baader solar film filter on the front.
Another good item is a continium filter that passes through at the 540nm range so green in appearance but the sunspots are supposidly more detailed. Never found I use enough magnification for "big" sunspots and there is at present precious little on tne sun anyway. Slight hiccup of a continium filter is the cost, they are not inexpensive for what is a green filter.
You may want to get a UV/IR cut filter in there. Sort of extra protection and if doing outreach nice to be able to say one is installed.
From memory I do not think you will necessarily need a "finder". Sure the Baader projects the image of the sun on to a rear screen with a cross on it. You manouvre the sun image on to the cross and the sun should be central in the scope/wedge setup.
Just remember it is still only a "white light" image, not the detailed Ha or CaK.
  • Jethro7 and LU1AR like this
#4 Avgvstvs
Avgvstvs
  • Loc: Australia
Posted 03 March 2021 - 03:21 AM
The old prism is a great way to do white light solar observing.
Image quality is much better than full aperture solar filters.
And a great way to see if solar is for you before you invests 1000's on that perfect solar scope
I had a 2" Lunt wedge which was great, most come with ND filters ready to go
#5 philmor56
philmor56
  • Loc: Bolton, ON
Posted 03 March 2021 - 06:49 AM
Hello Cners,
Here's a recent thread that may be of use.
https://www.cloudyni...erschal-wedges/
Cheers
#6 Jethro7
Jethro7
  • Loc: N.W. Florida
Posted 03 March 2021 - 08:52 AM
Cheers
Hello thank you noise jammer, SG6, Avgvstvs and philmor56,
The Baader wedge comes with a solar continuum filter, I have all of the other filters on hand.
I appreciate the tips and the knowledge that the Baader wedge is a good way to go for white light observation.
When I get home from work I will read up on the threads.
HAPPY SKIES AND KEEP LOOKING UP Jethro
#7 starbug
starbug
  • Loc: Southern Germany
Posted 03 March 2021 - 09:41 AM
The Baader wedge comes with ND3.0 and Solar Continuum installed. In the Photographic version lighter ND filters (ND 0.6 / 0.9 / 1.8) also included in the package.
Have it (photographic set), like it.
  • Jethro7 likes this
#8 noisejammer
noisejammer
    Fish Slapper
Posted 03 March 2021 - 10:19 AM
My experience is that the permanently installed ND3 filter is not enough for comfortable visual observing although it has dimmed the Sun's light by roughly 70% compared with naked eye observation (assuming a 6" refractor and a 2 mm constricted pupil.)
Before migrating to the 540nm filter, I tried a ND2 and rotatable polariser. I find the polariser most comfortable but the continuum filter offers the most surface detail.
It's unlikely to matter in our lifetimes but I was able to observe the cyan blue (nitrogen) ring around Venus during first contact of the 2012 transit. This would have been missed if a narrow band filter was in use. (I missed it in 2004 for both contacts because I was using a Thousand Oaks objective filter.)
