1x Field Flattener for Meade 6000 80mm? What works?
3 replies to this topic
#1 aatdalton
aatdalton
Posted 03 March 2021 - 02:54 AM
Hi all, just purchased a Meade 6000 series 80mm triplet and I'm looking to find a 1x field flattener to match it. Anyone have any experience with this? Will be for photographic work with an APS-C sensor.
#2 ratskrad
ratskrad
  • Loc: Heber Utah
Posted 03 March 2021 - 03:26 AM
While not the same scope but similar in specs and optics I use an Astro Tech AT2FF on my WO GT81 IV to get pretty good results. I find no need to crop due to bad stars. I am using an Orion G26 OSC on this setup and it uses an APS-C chip and no issues capturing all that the sensor sees.
#3 aatdalton
aatdalton
Posted 03 March 2021 - 03:42 AM
That's actually the one I'm looking most closely at right now so good to hear it's working for you.
#4 Mark Eby
Mark Eby
  • Loc: San Giego, CA, USA
Posted 04 March 2021 - 02:18 PM
I've used the AstroTech AT2FF field-flattener on the following scopes with results as indicated:
    Excellent:
        Astro-Tech 8" F8 1600mm FL Ritchie-Chretien
        TS-Optics 130mm F7 910mm FL Refractor
    Very good:
        Orion 80mm F7.5 600mm FL Refractor
        Explore Scientific 80mm F6 480mm Refractor
    Improved but not as good as the recommended focal-reducer/field-flattener from StellarVue:
        StellarVue 70mm F6 420mm Refractor
As you can see, the shorter and faster the scope, the more field-curvature, and the less effective the AT2FF is. In all cases above the spacing was fine-tuned. Start with the recommended 55mm. If the corner-stars are "pointy" (elongated toward the center of the image), increase the spacing. If the stars are "flat" (compressed toward the center of the image), decrease the spacing. You'll probably get the same results as I did with the ES80: very good but not perfect.
Have fun!
PS: Sensor is C size, ZWO ASI1600
Edited by Mark Eby, 04 March 2021 - 02:20 PM.
  • aatdalton likes this
