should flats be pure white?
Astrophotography
4 replies to this topic
#1 belliott4488
belliott4488
  • Loc: MD, US
Posted 03 March 2021 - 08:02 PM
I attempted my first-ever set of flats this morning, following the advice of Trevor from AstroBackyard and using the morning sky to light my double layer of tee-shirt stretched over my 8" Newt. I was surprised (although I'm not sure why, in hindsight) that my flats all came out pale blue. I guess the sensor was "seeing" the blue sky through the tee-shirt.
Is this okay? Disastrous? Does stacking software consider the color content of the flats or only the monochrome value?
#2 dhaval
dhaval
    Vendor
  • Loc: Round Rock, TX
Posted 03 March 2021 - 08:05 PM
You should look at the histogram and figure out if it is within the linear range (typically between 1/3 to 2/3 of the maximum well depth for a 16-bit camera). The "color" makes no difference, unless what you are seeing is complete saturation of all the pixels (in which case the histogram is way beyond the 2/3 well depth).
CS!
  • DRK73 likes this
#3 belliott4488
belliott4488
  • Loc: MD, US
Posted 03 March 2021 - 08:52 PM
CS!
Yes, thanks - I did check the histogram when I was choosing my exposure time (shutter speed), and it was between 25% and 50%. I'd expected a sharp peak but instead got more of a bell shape on the left with a steep cutoff on the right. Not sure if that's optimal ...
#4 dhaval
dhaval
    Vendor
Posted 04 March 2021 - 11:52 AM
I would think that should be fine. Have you tried calibrating lights with the flats? Try and see what happens. If it over or under corrects, you will know you have a problem.
CS!
#5 Borodog
Borodog
Posted 04 March 2021 - 02:18 PM
I think the master flat is typically converted to monochrome before being used for correction, so as long as all the channels are well exposed I think you should be fine.
  • belliott4488 likes this
Also tagged with one or more of these keywords: Astrophotography
