Anyone experienced all frames being lost from an ASI 290MM mini? I'm losing contiguous blocks of 3-15 seconds worth every 20-30 seconds while guiding right now.
Tried many USB cables, making sure the cables are clean, USB hub and direct laptop port, different laptop ports, varying exposure times, altering the USB limit in PHD2, and rebooting the system. Everything worked fine until a few days ago, and nothing should have changed since then. I've basically disassembled and reassembled everything tonight and it's still dropping frames. Using the ASCOM drivers, which as I said worked fine before. Cables tested are between 3 and 10 ft, which worked fine before. First experienced this about 2 days ago, and it seems to be getting slowly worse.
Any suggestions of other things to try? Would appreciate any input.
