Rosette... L-Enhance really helps the achro
7 replies to this topic
#1 sbharrat
sbharrat
  • Loc: NJ, USA
Posted 04 March 2021 - 10:21 PM
Still working with an Orion ST120 achro, so my stars are usually very bloated until this one. The L-Enhance really helped with my stars. The achro issues probably still clear to the experienced but for me, it's like I got an apo loaner!! lol.gif
Imaging: Orion ST120 (no FF), Canon 1000D 800ISO, L-Enhance
Guiding: Orion 50mm, ASI120mm
Mount: Sirius EQ-G
Lights: 197x180s, darks, flats, bias
Processing: PixInsight
Comments/criticisms/suggestions/pointers always welcome and appreciated.
https://astro.bharra...c49-feb2021.jpg
dcrop -> DBE -> PCC -> MLT denoise -> HTF -> ASINH -> starnet ->
(nebula) TGVDN (masked) -> CURVES (masked)
(stars) CURVES (reduce greenish in stars) -> HTF (dim)
pixmath to recombine
  • John Harrington, Poynting, Fernando134 and 11 others like this
#2 jonnybravo0311
jonnybravo0311
  • Loc: NJ, US
Posted 04 March 2021 - 10:45 PM
The blue wavelengths are cut below like 480nm... which certainly helps to contain the bloat caused by the achro. The L-eXtreme would be even more contained since it's only 7nm around the O3 line - basically eliminating almost all blue.
Nice image of the rose! I'm hoping to get some data on it with my new setup... picking that up tomorrow and so far clear skies are forecast for tomorrow and Saturday nights. I got some time on it last night with my Lumix G9... definitely need a whole lot more integration, but what I got looks pretty decent so far. Basically it was a test run for when I have the new kit :)
  • sbharrat likes this
#3 ram812
ram812
  • Loc: Grants Pass, Oregon. Originally Los Osos/Morro Bay, California
Posted 05 March 2021 - 12:00 AM
Mount: Sirius EQ-G
Great pic! I wonder, did you use an IR/UV cut filter? Not suprised some of these filters can actually improve what can come out of a relatively inexpensive refractor. Keep up the good work! I may try one on my ST80 just to see how they do(OSC). Thanks!
CS, Ralph
#4 petert913
petert913
  • Loc: Silverton, OR
Posted 05 March 2021 - 12:14 AM
Wow.  Nice tight stars and no purple haze !
#5 Avgvstvs
Avgvstvs
  • Loc: Australia
Posted 05 March 2021 - 12:33 AM
Image looks fantastic for an achro
#6 sbharrat
sbharrat
  • Loc: NJ, USA
Posted 05 March 2021 - 08:08 AM
Nice image of the rose! I'm hoping to get some data on it with my new setup... picking that up tomorrow and so far clear skies are forecast for tomorrow and Saturday nights. I got some time on it last night with my Lumix G9... definitely need a whole lot more integration, but what I got looks pretty decent so far. Basically it was a test run for when I have the new kit smile.gif
Yes, I noticed you updated your equipment signature as soon as you placed the order lol.gif
  • jonnybravo0311 likes this
#7 sbharrat
sbharrat
  • Loc: NJ, USA
Posted 05 March 2021 - 08:17 AM
CS, Ralph
Thanks! This is a *unmodded* Canon 1000D... so no additional IR/UV filter needed. But I think even if it was modded, the L-Enhance would cut out the IR/UV too...
  • drd715 likes this
#8 F.Meiresonne
F.Meiresonne
  • Loc: Eeklo,Belgium
Posted 05 March 2021 - 09:15 AM
The L-enhance seems a real nice thing. But you have to work on the stars. In achro this might be an advantage in an apo..well you get blue or even greenish stars...and they are all thesame
I worked on a b-color version  showing the outer Ha regions and the inner cyan OIII/Hb
I used the L-enhance stack for Luminance about 3 hrs and i used an unmodded OSC stack, aligned them and processed them in Startools.
If you look carefully  starcolors are a bit back, got some white but there are some yellow stars again also, and well still too much little blue ones...
Still got experiment on it, but it looks like a work around for the killed star color with the L-enhance.
Image itself is perhaps less appealing then a full nice red one, but the Rosetta does contain OIII and that is not  fully red..
The L-enhance also cuts back moonlight quite a bit, half of the stack was with a half moon in the sky about 25° from the object, this opens possibilities...
  • Ivo Jager and sbharrat like this
