Before Televue introduced their pvs-14 adapter in conjunction with TNVC in 2017, most night vision use was, to my knowledge, done in "prime" mode. However, unsurprisingly, given Televue's status, afocal night vision observing has become much more popular since then. There's been several threads on afocal versus prime nv use since then, but having been an afocal only user, in October last year I got my first night vision monocular that can do prime, the ovni-m. I thought it may be useful for some to describe my thoughts after comparing directly the two approaches.
From a personal perspective, being based in the UK, the introduction of the Televue afocal adapter enabled me to put together an excellent European night vision setup using European sourced PVS-14s which contained a very good Gen 3 German Harder Digital white phosphor tube (FOM 2400+, with EBI less than 1, and gain 60k+). It was a massive breakthrough for my DSO observing, and even though I couldn't do prime I was very satisfied with my results both live visual observing and taking quick phone snaps.
I have a range of scopes that I use with nv from a little 40mm askar refractor through a 130mm refractor, a 11inch sct and all the way to a 16 inch f4 dob, which has enabled me to do quite a few different comparisons. My ovni-m has the same make of tube (harder digital) and similar, but slightly superior specs to my pvs-14 (FOM 2600+, ebi, less than 0.5, gain 70k+).
As some of you will know, for live nebulae observing, my personal preference is to see as much of the nebulae detail as possible and bright views, I don't mind attenuating the fainter stars since it's the nebulae I am most interesting in seeing). This has meant I mostly observe afocally with the 67mm televue eyepiece to get a effective fast f ratio system (f2.5 or less) and a very narrow ha filter 3nm, to maximise nebulae contrast.
With the ovni-m I'm now able to observe in prime mode but this means that my systems have a much slower effective speed of around f4 to f5.5. I have also found using reducers in prime mode problematic because they require quite a bit of in focus which I don't have and so can't get into focus. At these slower speeds the live visual views are nowhere near as nice for me personally as they are much dimmer which means that the gain can't be turned down as much to reduce scintillation. In the fast afocal setups, I can turn gain down to effectively remove scintillation, give great "natural" views, but still get nice bright nebulae detail. Also the afocal setups handle the very narrow ha filter much better due to the faster system speed. I find the very narrow ha filters bring out the contrast better. In prime mode I prefer my 5nm filter to reduce the scintillation a bit but I don't get the same level of contrast.
Where I do prefer prime mode is taking my quick phone snaps. Prime mode gives lovely tight stars to the edge of the field of view and I can easily adjust the iso up a little to increase the brightness with limited impact on noise. In afocal mode it is difficult to get good edge stars due to the fast system speed and the 67mm eyepiece giving edge aberrations (55mm plossl even worse in this regard, 41mm panoptic better). In addition with my dob I do get some reflections on the brightest stars from all the glass in the setup (I think). I can now get some attractive phone pics with my dob which I struggled when just using afocal.
My ovni-m can do afocal observing but from my personal experience, the pvs-14 is better in this regard for a couple of reasons 1) the pvs-14 front lens has a thread in it which means that it can be secured firmly to the televue eyepiece with the televue afocal adapter. My ovni-m doesnt have a thread in its 1x lens so the afocal connection is push fit or with an external bracket attached to the body itself which I don't find as good. 2) The front lens on the pvs-14 is excellent in my opinion particularly as it operates at a very fast f1.2, it was specifically designed for nv usage and it shows. Other 26mm c mount lens I have tried haven't been as good particularlyas you move towards the edge of the field of view. The front detachable 1x lens supplied with my ovni-m is ok but the pvs-14 is noticeably better in 1x and afocal mode. The envis lens (now discontinued, difficult to find in the USA and impossible to find in Europe!) is I understand the same quality as the pvs-14 front lens, but I also have also read that the envis lens requires a large move to twist to focus whereas the pvs-14 is more swift in this regard.
The adjustable gain knob on my pvs-14 is excellent and can be twisted in an analogue way to get to my perfect setting, the ovni-m gain is a digital push button which works but is not quite as easy to use. Finally the pvs-14 has a really nice amount of eye relief which making observing with and without glasses so easy and pleasurable. The ovni-m specifications show a long eye relief in excess of 20mm, but in practice I find I need to push my eye in closer than the pvs-14 to see the whole fov.
So my conclusion is for live visual observing I will be using the pvs-14 with 67mm (and maybe 55, and 41mm on occasion), and for my quick phone images I will swap in my onvi-m with 5nm filter for better edge stars and zero star reflections.
Here are my night vision monoculars, 3 pvs-14s (one with photonis 4g tube, 2 with harder digital grr we n 3 tubes) and my ovni-m with harder digital gen 3 tube.
Edited by Gavster, 05 March 2021 - 07:39 AM.
