Ok freedom find I get as it doesn’t loose its alignment when the scope is moved manually,however to the very best of my knowledge is the WIFI icon just means its compatible to other devices as mentioned skywatchers own app.it seems to me you still need the skywatcher WiFi module this usually plugs in to the auxiliary port of the mount!? Then there own app is downloaded form smartphone or iPad
then the useall process for skysafari you need to puchase the skyfi WiFi module separately this is required to operate the scope in the skysafari app which also is downloaded at a small cost.then what you need to do is connect the WiFi module via usb or pc connection with a cable which runs to the auxiliary port Next to the synscan HC cable goes then the synscan cable goes to the side of the azimuth base of your dob.
then once the scope is aligned from your synscan HC then what happens is you switch the skyfi module on as the WiFi signal processes you can then go into settings click on skysafari etc then the scope should be connected.however it’s also. Important that you go through sky safari settings click on telescope brand name telescope type ie azimuth,Equatorial click on that then you should be ready to control from the skysafari planetarium app and a round curcle with cross hairs should appear on the same object you previously aligned with the synscan HC.
Edited by Supernova74, 05 March 2021 - 11:55 AM.
