How do I mount an Orion ShortTube 80 Refractor Telescope Optical Tube Assembly
4 replies to this topic
#1 Cali
Cali
  • Loc: Bay Area
Posted 05 March 2021 - 10:54 PM
How do I mount an
onto an
Orion Apex 127mm Maksutov-Cassegrain Telescope
Please, don’t ask why...
Thx!
- Cal
Edited by Cali, 05 March 2021 - 10:55 PM.
#2 Jeffmar
Jeffmar
  • Loc: salt lake city, utah
Posted 05 March 2021 - 11:15 PM
You can get mounting rings that will fit each telescope. Most mounting rings will have a place on the top where you can bolt on a rail for to mount another telescope on top or just both the upper rings to the lower rings without rails. Theoretically, you could stack 5 or 6 telescopes on top of each other with mounting rings. I would guess OrionTelescopes would have rings to fit both telescopes. Look in the accessories category on the Orion website.
92c15ea18e5432def8f975022d1053a4
Edited by Jeffmar, 05 March 2021 - 11:39 PM.
  • ram812 likes this
#3 ram812
ram812
  • Loc: Grants Pass, Oregon. Originally Los Osos/Morro Bay, California
Posted 05 March 2021 - 11:48 PM
Hello!
I would remove the bottom dove tail from the Mak and replace that with a pair of hinged clam- shell type ring set, which have threaded hole on top. You can then either direct bolt a dove tail(Orion pt#07382) similar to what's on the bottom now (But longer)to the top and mount the ST80 via it's own hinged clam shell rings(Orion pt#07370) or go with guider rings,(Orion pt# 07381). I'm not sure what type of rail you would use to attach the whole setup to the mount but for me I have a CGE#94214, but I'm mounting the ST80 with an Orion helical guider on top to a CGEM. Hope this helps!
CS, Ralph
Edited by ram812, 05 March 2021 - 11:56 PM.
#4 junomike
junomike
  • Loc: Ontario
Posted 06 March 2021 - 09:12 AM
I'd mount a Finder Shoe on the 80mm and use the Mak's Finder Base.
#5 BlueTrane2028
BlueTrane2028
  • Loc: 40°28'36.8"N 75°12'30.5"W
Posted 16 March 2021 - 10:57 AM
If the idea is to be able to see a wider view at an instant while using the Mak, sounds great to me.
That said, I went and bought a NexStar SLT mount for my ST80.  I often set it up right next to my own Apex 127, which rides in a NexStar SE mount.
The Apex works far better with a wide field 2" eyepiece than I expected it to, however, so there are nights that I skip the ST80.  If you haven't tried that yet, it's worth it.
