Stacking pleiades and mars - 91x2min
Planet Astrophotography DSO
3 replies to this topic
#1 jarosatori
jarosatori
Posted 06 March 2021 - 05:57 PM
Hi, I cannot find a way how to stack 91x2min exposure of Mars and pleiades. I have shot the conjunction but I cannot find the way how to do it so the Mars will be as a single point. I tried to do it in pixinsight. The results are very odd as the moving mars causing real problems to my final image... laugh.gif I would be grateful if somebody is able to advise me or send me some manual how to do it smile.gif Many thanks
Edited by jarosatori, 06 March 2021 - 06:11 PM.
#2 tlindema
tlindema
Posted 06 March 2021 - 06:15 PM
I don't think any stacking software will keep Mars at a single point, since it is actually moving with respect to the stars. I encountered the same issue over a 2.5 hour imaging session. My solution was to stack less exposures (~15 min) for Mars, and blend it into the longer exposed image in Photoshop.
Edited by tlindema, 06 March 2021 - 06:16 PM.
#3 happylimpet
happylimpet
  • Loc: Southampton, UK
Posted 06 March 2021 - 06:21 PM
Stack it normally and with Mars as a comet, and then merge the images in photoshop.
Edited by happylimpet, 06 March 2021 - 06:22 PM.
  • B 26354 and Anhydrite like this
#4 jarosatori
jarosatori
Posted 07 March 2021 - 04:35 AM
Thank you. I tried it as a comet. It still does not work, but I hope I will somehow solve it today. Pixinsight has quite a problem to get rid of the Mars when it is trying to do it with 91 frames. Should I maybe try less images? It seems thart result is better when I use very low value in Image integration -> Pixel rejection( 2) -> sigma high (I set it below 1) when trying to stack Mars as a comet after comet alignment - but there are still some artifacts which stayed after bright stars and nebulae in the Pleiades, but it is manageable I think. What is worse is that I do not have good results from stacked picture of stars without the mars. I have there and an artifacts around the stars and I have there an odd red shape instead of Mars... Any ideas how to set values in image integration properly  when stacking Image which was substracted from the frame of a comet (comet alignment -> substraction and as a file I use stacked Mars without stars)? Or any other tip what I do badly in process? :)
Edited by jarosatori, 07 March 2021 - 04:43 AM.
Also tagged with one or more of these keywords: Planet, Astrophotography, DSO
