Dithering issues
6 replies to this topic
#1 kevin.mcde
kevin.mcde
  • Loc: Norther New Mexico
Posted 07 March 2021 - 10:29 PM
Hello!
I've been using my smaller SV70T so long that when I pulled out my C9.25 last night there were...some issues to say the least. After using the smaller scope so much, I forgot how unforgiving the C9.25 can be. Between guiding, dithering, and calibration frame problems it was a long night.
My primary concern at the moment is the dithering.
With my SV70T, the communication with SharpCap and PHD2 is wonderful. I have it set to dither every 240 seconds and it works like a charm.
However, with the larger scope, dithering occurs but then it never starts capturing again. I suspect I have the dithering setting wrongs for a larger scope since it is less forgiving.
Setting are:
Dither interval: 240sec (I do 120 second shots so dithering after 2 shots, which has been fine for my smaller scope)
Max dither step: 20 pixels
Settle threshold: 3 pixels - I feel this could be an issue but not sure where to set it
Min settle time: 5 seconds
Max settle time: 60 seconds (max setting)
Any ideas on what I need to fix?
Kevin
#2 AhBok
AhBok
  • Loc: Lakeland, TN
Posted 08 March 2021 - 07:00 PM
I assume you are using an OAG with the same setup as the Apo? Are you using a .63x reducer?
#3 gcardona
gcardona
Posted 08 March 2021 - 07:06 PM
I suspect your settling threshold is too low for your SCT, and the guider can never settle to within 3 pixels.
#4 kevin.mcde
kevin.mcde
Posted 08 March 2021 - 08:03 PM
No on axis guider. I am using a 0.63 reducer.
#5 kevin.mcde
kevin.mcde
Posted 08 March 2021 - 08:04 PM
That is high on my list. Just not sure what the setting should be.
#6 don314
don314
Posted 08 March 2021 - 09:33 PM
PHD2 instructions for Settling setting (as a starting point),  in PHD2 under "RMS Error:" it gives RA, Dec, Tot. errors in pixels followed by arc-seconds in parentheses.   Multiply the "Tot" Pixel value by 2, and enter result in "Settle at <  ?? Pixels".  I'm typically close to 0.45 pixels, so use a value of 1, seems to work OK for me.
#7 kevin.mcde
kevin.mcde
Posted 10 March 2021 - 08:40 PM
Thanks. If the clouds ever clear I'll give it a try.
