Is the Unitron Unihex a good turret?
43 replies to this topic
#26 Bomber Bob
Bomber Bob
  • Loc: The Swamp, USA
Posted 10 March 2021 - 10:10 PM
I got my Unihex from Johann, and used it all the time with my Sears (AO) 76x1200.  I had spare parts to adapt it to both .965" & 1.25" focusers:
I really don't care for Zoom Eyepieces.  Having 6 high-quality EPs in the Hex is the better solution -- rotate CW/CCW to zoom in / out:
As for quality .965" eyepieces:
- I got my 1980s Meade (Tani) Series 2 and my 1980s spectros (Swiss) sets here on CN.
- With careful shopping, got my Zeiss EPs on eBay from Sellers in Germany.
Remember:  These Classic LONG Refractors were designed for this "Japanese" Standard barrel.  Also, the bundled / intended eyepieces were small & light (along with the diagonals), and those models with the long 30mm chrome manual / coarse focus like the AO & Towa F15 fracs, can sag under the additional weight of a loaded Hex...  (You can stiffen up / add supports to this tube.)
But Honestly:  The 1980s Vixen 4-slot turrets are better mechanically; and, at least with mine, are easy to adapt from SCT to standard barrel sizes.
  • Jim Curry, Terra Nova, rcwolpert and 1 other like this
#27 starman876
starman876
    Nihon Seiko
  • Loc: VA
Posted 10 March 2021 - 11:23 PM
+1
I became a real fan of 0.965” eyepieces once I pieced together a nice set of quality oculars. I like them much better than kludging 1.25” eyepieces onto a 0.965” focuser. I also have a Unihex that is of excellent build quality, but it seems to be one of the older models that is a bit tough to adapt to a 1.25” draw tube. I pieced together a Terra Nova adapter, but the threads didn’t match those on my Unihex. frown.gif
I’ll figure something out.
There is a unitron adapter that allows 1.25" eyepieces. Also the Astronomy Shoppe makes 1.25" adapters for unitrons.
#28 CHASLX200
CHASLX200
  • Loc: Tampa area Florida
Posted 11 March 2021 - 06:44 AM
Off topic - a Unihex is definitely for old refractors only, and no-one puts a turret on a dob.
We were talking about .965" OD eyepieces and FOV.
#29 jgraham
jgraham
Posted 11 March 2021 - 07:56 AM
The adapter that I mentioned replaces the nosepiece of the Unihex so that you can use it on a refractor with a 1.25” draw tube. As-is my Unihex was designed for a Unitron draw tube which is a bit bigger than 1.25”. I haven’t tried it on my larger refractors yet that have a 2” focuser.
Further though is necessary...
#30 Terra Nova
Terra Nova
  • Loc: 39.07°N, 229m AMSL, USA
Posted 11 March 2021 - 08:37 AM
+1
Wow, mine threads perfectly. I wonder why your’s doesn’t. I didn’t know they ever varied the thread spec? My Unihex dates from around 1956. It’s threads are the same as the standard Vixen 34.6mm spec. That’s the way I came up with the idea of the adapter was fiddling around with a Vixen 34.6mm/1.25” visual back.
Edited by Terra Nova, 11 March 2021 - 08:52 AM.
#31 jgraham
jgraham
Posted 11 March 2021 - 09:06 AM
I ordered the exact parts that you listed and they look great! However, I thought that I read somewhere that at some point they changed the thread pitch. There was something about the style of lettering on the Unihex that you could tell which was which.
It's okay, I'll figure something out, just gotta find the time to fiddle with it a bit.
#32 Terra Nova
Terra Nova
Posted 11 March 2021 - 09:15 AM
That could well be the case since the thread was only used by Unitron in mating the nosepiece tube to the Unihex body and no where else to my knowledge, and the specific nosepiece tube (that slips into the standard Unitron focuser sleeve) and the Unihex body itself were always sold as a unit. My Unihex has the block letters btw.
#33 Terra Nova
Terra Nova
Posted 11 March 2021 - 09:23 AM
It should also be noted whilst on the topic, that the larger eyepiece tube on the standard Unihex, often referred to as the ‘1.25” eyepiece holder’ isn’t really 1.25” and if you put a heavier 1.25” eyepiece in it, like a TV Nagler or Panoptic, it could easily fall out, that being a rather costly mistake. That’s because that eyepiece holder is intended for the wide-field Unitron 40mm Monochrome or ‘Mono’ eyepiece, and that is not a standard 1.25” eyepiece. It is in fact much closer to 1.27” in diameter, and that is why some non-Unitron classic eyepiece collectors have found out that it won’t fit their 1.25” diagonals after purchasing one.
  • rcwolpert likes this
#34 starman876
starman876
    Nihon Seiko
  • Loc: VA
Posted 11 March 2021 - 09:24 AM
Unitron cottage industries in Japan did not follow thread standards in all production.   NS had many different vendors to supply the parts that made up a Unitron.
  • Terra Nova likes this
#35 Tiredeyes
Tiredeyes
  • Loc: Maryland
Posted 11 March 2021 - 10:12 AM
I have a Polarex labeled Unihex that definitely has a different thread for the drawtube than my Unitron labeled Unihex.
  • Bomber Bob likes this
#36 starman876
starman876
    Nihon Seiko
  • Loc: VA
Posted 11 March 2021 - 04:18 PM
That is also true of the Unitron unihexes I have had and still have.   The one drawback of all the unihex parts I have is the threads are not the same for certain parts over the years.  However, the lens cells always screw on without a hitch,  does not matter what year.   Wonder if NS made those in house?  The cells did change over the years because the lenses did.  Some lens sets are thicker than others showing they came from different sources.
  • Terra Nova, rcwolpert and Bomber Bob like this
#37 Kasmos
Kasmos
  • Loc: So Cal
Posted 12 March 2021 - 05:41 PM
My 114 is a standard issue model with a diagonal and porro. I'd thought about getting a Uni-hex, but the more I thought about it the less I wanted one. I almost never use more than 3-4 EPs in a session and don't need the extra weight or the worry of an EP slipping out. Also have no need for the 1.27" barrel for the 40mm Mono. I'd rather have one of those .965" 4 EP turrets (with thumb screws) that Celestron and Meade sold and probably still wouldn't use it much.
Instead of a Uni-hex, it would have been nice if Unitron put a EP tray on the tripod. And yes, I realize that later model 114s had a small one.
#38 Bomber Bob
Bomber Bob
Posted 12 March 2021 - 06:01 PM
I used the C/V 4-slot turret on the Tak FC-50 last night for doubles.  Great Combo!  No tray on the VG2, and I move this scope around a lot to dodge trees.
Edited by Bomber Bob, 12 March 2021 - 06:23 PM.
  • Terra Nova, rcwolpert and Kasmos like this
#39 starman876
starman876
    Nihon Seiko
  • Loc: VA
Posted 12 March 2021 - 07:22 PM
got to watch out for those trees.  They do not like astronomers.
#40 pdxmoon
pdxmoon
  • Loc: Oregon
Posted 12 March 2021 - 09:48 PM
I don't even care if it works--it just looks so cool I enjoy the sight of it!
#41 Bomber Bob
Bomber Bob
Posted 12 March 2021 - 10:02 PM
BIF:  The .965" Hex adapter I made had a standard threaded chrome barrel, so I could put any .965" filter on the nose; and, as I had the Barlow that came with the '78 Tasco's photo kit, that lens fit, too -- but the distance made it about 4x factor.  The eyepiece had to be 20mm or higher, or the views were SOFT.
#42 JonH
JonH
  • Loc: Brisbane Australia
Posted 13 March 2021 - 03:15 AM
I like the Unihex B which is all 1.25 holders. But they arnt close to par-focal like the A unihex is. The superunihex not so much, apart from being able to mount the 60 mm giant eyepiece as part of a set its big and heavy and looks a bit meh (apologies if its your fav).
Clear skies
#43 CHASLX200
CHASLX200
Posted 13 March 2021 - 06:59 AM
I never really used my turrent back in the day with heavy eyep's. It was just used for looks in the living room. But boy did them Meade SWA's and UWA's make that Unitron shine on the views.
  • JonH, rcwolpert and Bomber Bob like this
#44 starman876
starman876
    Nihon Seiko
  • Loc: VA
Posted 13 March 2021 - 09:53 AM
It is a shame that is so true.   the first time I used 1.25" eyepieces in my model B's I noticed that.   I was like what!!!!
