Hello all, I have a nexstar 8SE mount with a single aux port. I am running a wifi portal so got the Celestron dongle. I am now looking to add starsense and potentially the celestron motor focuser. So I need 3 aux ports
here are my 3 Qs:
(1) how do I get to 3 AUX without daisy chaining. Does the handset utilise an Aux port where I could also use another splitter to end up with 4 Aux total which would fit my purpose?
(2) I am running the Nexstar off a Celestron Lithium 7.2 Ah LiFePO4 Powertank. Is that likely up to the task of powering all those electronics?
(3) it looks like any focuser (celestron or two) may interfere with a DSLR mounted prime any opinions on that? it's a tight space between the SCT and mount base but I plan to use an extended dovetail to gain an inch or so
Thanks for guidance!
