This is very intruiging
Actually, I was wondering when this was going to be done - it's basically a fully configurable system, like Borg, except it uses M42x0.75 threads. You can basically build your own scope
Hopefully this will catch on; there exists already a plethora of M42 accessories, including tubes of varying lengths, visual backs, camera mounts, filter slides, helical focusers - and now an M42 compatible crayford focuser. I'd love to see a range of small objective lenses with M42 threads, both achromatic and apochromatic.
You could build a guidescope, finderscope, visual RFT, astrograph, EAA scope, binoscope, heck even hand-held binoculars that utilise 1.25" eyepieces! (would love to see some sort of hinged dual-tube holder, and M42 roof prisms for this purpose)
Where did you read that this Aliexpress/Laida scope used M42 threads for anything other than the connection at the end of the 1.25" eyepiece holder? On the Laida scope it does NOT appear that the optical tube itself, the lens cell, or the Crayford focuser connect to each other using M42 threads.
Furthermore, it isn't that unusual for small scopes and lenses to terminate with M42 threads (I have several that do). In fact, my SVBony 30mm f/4 finder has M42 threads on both ends (at the eyepiece connector and for the lens cell itself). Also, the Feather Touch 1.25" Crayford focuser that is on my Lunt LS50 solar scope terminates with an M42 thread (as well as accepting 1.25" eyepieces). And, for that matter, you can already get a Borg that uses M42 on the camera or eyepiece end of scope. But, admittedly my Feather Touch and any Borg scope is going to be more expensive that this Laida finder from Aliexpress and I do look forward to seeing how users rate the quality of its focuser.
Edited by james7ca, 13 March 2021 - 03:38 AM.
