I was able to split the double star Porrima using about 80X via a 2.5mm Tele Vue Nagler type 6 eyepiece. It was easy, more than a figure eight but I don't think I would claim clear dark space between the two stars. Porrima is currently at a separation of 3.1 arc seconds and Dawes' Limit for a 50mm aperture is 2.32 arc seconds. For this and the following tests I was using a Stellarvue 1.25" dielectric coated, 90 degree, mirror diagonal.This requires the removal of the long, 75mm extension tube that I discussed in my previous post.
It will be interesting to see what Lyra's double-double star will look like with this scope, being that the widest pair of those stars is current separated by 2.3 arc seconds. For that I'll probably need to use a barlow, since I have a 2.5X barlow that can be paired with a 4.5mm Tele Vue Delos eyepiece (giving a magnification of about 111X).
I looked at Castor (separation 5.4 arc seconds), if was easily and cleanly split with two separate Airy disks surrounded by some wavering diffraction rings.
The scope does show a little color on the very brightest stars, but I don't think it really detracts from the view. However, there seems to be a very slight warm coloring on bright stars, so they look very slightly yellow rather than white. That said, I never had completely dark skies and the marine layer clouds arrived before the start of astronomical dusk. I was able to find the globular cluster M3 (again before full darkness) using 80X with the Tele Vue Nagler (M3 imaged __HERE__ from a few weeks ago). Not much to see -- visually -- on M3, just a faint, hazy glow surrounded by some dim field stars.
I also tried to look at the star cluster M44, the Beehive, which I photographed using a 24mm Nikkor lens a few days ago ( __HERE__ ). Unfortunately, the marine layer had arrived before I got to that target and the only thing I could see through the clouds were the four keystone stars. In this case I was using a 24mm Tele Vue Panoptic eyepiece giving a magnification of 8X and a field of view just over 8 degrees wide. That field allowed me to frame both Castor and Pollux in one view, since those two stars are separated by about 4.5 degrees. At that wide of a field and with the stars equally spaced to both sides of the view there was a bit of a flare on both stars (neither was really a point of light, but not really that bad, and I don't know how much of this distortion was from the scope, or the eyepiece, or from my own eyes).
Overall the optical quality looks pretty good (for an f/4 achromat), easily good enough for a finder or guider. The focuser also worked well, but given that it is a 1X mechanism you have to have a pretty light touch when focusing at high magnifications.
Shown below, the Laida Optics 50mm scope on a Celestron AVX mount pointing toward the star Sirius (yes, it was still light outside as I started as early as possible because of the threatening marine layer clouds). In this case I was using a Baader 24mm, illuminated reticle eyepiece with a correct image, 45 degree prism diagonal.
Edited by james7ca, 08 May 2021 - 02:52 AM.
