What is the weight of the scope with diagonal? Ali states 120g, but that can't be right.
My scope is current configured with both tubes for imaging/guiding tests and with the scope, the clamshell rings and Vixen rail (mount that comes with the scope), and lens cap and eyepiece plug it weighs about 550g. However, it would be somewhat less than that without the 75mm long M48 tube and the lens cap and plug (which would be the working configuration when using a diagonal). Right now I don't want to detube and dismount the scope so I can't give the weight with the shorter configuration (using just the 50mm tube, see __HERE__ for the different configurations). To change configurations you have to remove the clamshell rings.
Edited by james7ca, 09 May 2021 - 10:15 PM.
