I have been working on getting a CG5-ASGT working for some wide field (700mm FL) astrophotography and I am trying to get guiding and dithering set up.
(yes I know I won't have the best results with this mount)
The hand controller is the Nexstar + model with an headset port on the bottom. I bought a Serial to USB converter with a prolific chipset and a Celestron specific cable to go from the handset to the Serial Port. After connecting the mount to a computer running Windows 10 I power up the mount while holding the info and undo keys and it says
"transmit data"
I have tried connecting to the mount with CFM and HCUpdate and both say no device found.
I am wondering if anyone else has had this problem and where I should go from here.
Trevor
Edited by terevorlein, 25 March 2021 - 07:25 PM.
