Brass Unitron 102mm F15 OTA
57 replies to this topic
#51 starman876
starman876
    Nihon Seiko
  • Loc: VA
Posted 31 March 2021 - 12:38 PM
I find it quite odd that it didn’t have baffles to begin with.
That tube is a Unitron home brewed project on Long Island.   They attached the lens cell and focuser and stopped there.  They were hoping I would finish the project.  I made sure the tube length is correct before I did anything else.   I have to check my stack of dew shields and see if any of them are brass. I will also copy the baffles from a normal 152 and space them the same locations in the tube.
Edited by starman876, 31 March 2021 - 12:42 PM.
  • Terra Nova, Bomber Bob and Defenderslideguitar like this
#52 semlin
semlin
Posted 31 March 2021 - 02:12 PM
not sure if this was already said, but there is a guy selling custom 3d printedaperture masks in the classified section.
they appear to be quite literally exactly what you need, if you are ok with plastic.
https://www.cloudyni...any-telescopes/
  • Bomber Bob likes this
#53 starman876
starman876
    Nihon Seiko
  • Loc: VA
Posted 31 March 2021 - 06:22 PM
Thanks for the tip.  Already talking with them on making some.   seems like surefire way of fixing the issue.
#54 ccwemyss
ccwemyss
  • Loc: Massachusetts
Posted 31 March 2021 - 07:56 PM
I'm also going to get one to see if it might work for the 6" scope. He says the material is good to 340 degrees. I want to see if it will take paint well though, and be sure the fit is good.
Chip W.
#55 starman876
starman876
    Nihon Seiko
  • Loc: VA
Posted 31 March 2021 - 08:02 PM
Chip W.
Great. Let's hope it works out for both of us.  Rustoleum makes a paint that works well on plastic.  Works on any surface they claim.
https://www.amazon.c...0016H2KJA&psc=1
#56 Terra Nova
Terra Nova
  • Loc: 39.07°N, 229m AMSL, USA
Posted 31 March 2021 - 10:13 PM
You could cut your baffles out of sheetmetal as per this:
https://youtu.be/8QsiOppAU1s
And sheetmetal is easy to paint flat black.
As far as spacing the baffles, you could use something like flockboard to keep the in place. The nice thing about flockboard is that it springs to shape and stays in place with no need of any adhesive. Just calculate the inner circumference of the tube and cut a sheet that long, the width of the sheet corresponding to the baffle spacing. I used Protostar flockboard in my 6” Newtonian and it’s still exactly where itmwas initially positioned.
#57 starman876
starman876
    Nihon Seiko
  • Loc: VA
Posted 01 April 2021 - 06:43 AM
I like the direction I am going in.  I order something and see if it works lol.gif
#58 starman876
starman876
    Nihon Seiko
  • Loc: VA
Posted 08 April 2021 - 09:08 PM
When I took the front lens cell off to insert the new baffles I found they had put a spacer at the end of the tube to take up the room between the cell and the brass tube.  Well that meant the baffles I just got had a diameter that was too small.  I figured the inside of the tube was the same diameter as the outside of a lens cell.  Guess I was wrong. frown.gif So I ordered some more baffles with the right diameter.  The spacer looks to be part of a 4" dew shield.   I will take pictures when the new baffles come in a couple of days.
