Out Struving last night in poor seeing, about Pickering 4/10..... 8-in Wirth Mak Newt.... Calm winds, Temps from 5C to 1C over 3 hour period.
Triple #1 in Eastern Monoceros. Easy with 17.3mm Delos (70x).
STF 1190 AB 4.46 10.32 33.2" 106º 08h 08m 36s -02º 59' 02"
STF 1190 AC 4.46 9.68 64.9" 246º
STF 1190 AD 4.46 13.40 39.0" 285º (I did not see this component at any magnification)
Triple #2 in Sextans. Fine with 12mm Delos (101x)
STF 1464 AB 8.26 10.26 5.80" 302º 10h 41m 35s -00º 16' 21"
STF 1464 AC 8.26 10.51 66.7" 226º
The double double in Hydra. A bright-ish pair and a much fainter pair only about 1' away to the north... The fainter 'pair' is not in the WDS and appears to be two field stars...
STF 1309 8.48 8.38 11.7" 273º 09h 06m 38s +02º 49' 06"
The fainter pair has magnitudes 11.84 and 13.21, sep. 28.2" PA 4.5º (data obtained from Sky Safari which conveniently gives separation and PA from the previous object you centered... So centre on 'A' and then centre on 'B' and read the data..
The 11.84 mag star is TYC 0229-2157-1 and has no other designation..
The 13.2 mag star is Gaia 577487219423400448 and has no other designation.
So, I proudly announce the discovery of Cotts 1.
Dave
