NGC3718, NGC3729 and Hickson56 2nd run
17 replies to this topic
#1 Mert
Mert
  • Loc: Spain, Pamplona
Posted 08 April 2021 - 11:26 AM
Hi all,
In my never ending struggle against the LP from my balcony I decided
to try and add another 7 hours of integration to my 1st run image.
Unfortunately the seeing was quit bad and also some overcast and a
sporadic cloud ( as seen in the guidelog ) spoiled the quality a bit.
Evenso I integrated all the frames from 040421  and 040721 for a
total of nearly 14 hours of integration.
I didn't use noise reduction to preserve some of the fainter outer arms of
the main object but evenso, they still don't stand out well.
Maybe I'm just running up against the limits what's possible from here
Details:  417 frames of 120 seconds, NINA in charge of everything and
preprocessed in APP and finished in Pixinsight.
Still not up to par with my processing, but here goes.
( for full res: http://lammertus.epi...on-UVIR-web.jpg)
Stay well,
Mert
Edited by Mert, 08 April 2021 - 11:27 AM.
  • Scott Mitchell, elmiko, BenKolt and 11 others like this
#2 ziggeman
ziggeman
Posted 08 April 2021 - 11:44 AM
wow! 14 hours of integration. Thats a lot. I think its a great image. And with a six inch. Amazing. I think I have to rethink my wish of great photos with only twenty to thirty mins exposure. ..I'm lazy it seems ;)..:)
#3 pyrasanth
pyrasanth
Posted 08 April 2021 - 11:52 AM
Hi Mert- that is getting much better. There appears to be far less noise- send me that master and I will see if I can get aligned with my LUM master- it might be a bit easier with a better less noisy image.
There are no limits- just time- keep at it- If I would have had the weather last night I would have put another 7 hours into my data as well- sadly I have clouds for a few days on the predicted forecast.
Edited by pyrasanth, 08 April 2021 - 11:59 AM.
#4 Lead_Weight
Lead_Weight
  • Loc: Houston
Posted 08 April 2021 - 11:55 AM
Mert, this looks great! Detail is definitely there. Looks like a color correction/balance issue.
#5 pyrasanth
pyrasanth
Posted 08 April 2021 - 11:57 AM
wow! 14 hours of integration. Thats a lot. I think its a great image. And with a six inch. Amazing. I think I have to rethink my wish of great photos with only twenty to thirty mins exposure. ..I'm lazy it seems wink.gif..smile.gif
From a Bortle 7-9 Sky this target needs 30-40 hours in the L channel alone on anything other than a really big fast telescope- the arms are very faint- Hubble makes everything look easy.
  • ziggeman likes this
#6 Mert
Mert
Posted 08 April 2021 - 12:31 PM
Hi Ziggeman,
I'm glad you like the image,
which is taken with an RC8 and ASI1600MCC.
Edited by Mert, 08 April 2021 - 12:32 PM.
#7 Mert
Mert
Posted 08 April 2021 - 12:35 PM
Hi Mark,
Yes it seems to get better so likely if weather clears up I'll continue to add.
I was lucky because when I woke up the sky was ink black!
Here is the master, did lp removal in APP: https://www.dropbox....c-cbg.fits?dl=0
Edited by Mert, 08 April 2021 - 01:31 PM.
#8 Mert
Mert
Posted 08 April 2021 - 12:37 PM
Hi Lead-weight,
I'm glad you like it!
Could you please expand a bit on the color correction/balance?
Hope to improve my processing skills :waytogo:
Edited by Mert, 08 April 2021 - 12:38 PM.
#9 pixlimit
pixlimit
  • Loc: Germany, Hamburg, Red Zone
Posted 08 April 2021 - 01:44 PM
balcony, Mert, great
#10 Mert
Mert
Posted 08 April 2021 - 01:51 PM
Thanks Peter,
Hope to make it look better processing but likely not much more that I can do.
Except for adding more hours ( much more ) to it.
Right now I'm trying to make the background look better.
Stay well,
Mert
#11 Scott Mitchell
Scott Mitchell
  • Loc: Atlanta-ish, GA
Posted 08 April 2021 - 03:11 PM
Looking good Mert! You're a better purist than I am with staying away from noise reduction. wink.gif
#12 Mert
Mert
Posted 08 April 2021 - 03:30 PM
Hi Scott, thanks!
I'm busy with a version 2 to get the background better.
On this version 2 I did noise reduction with EZ denoise.
Will post that version later on or tomorrow.
  • Scott Mitchell likes this
#13 elmiko
elmiko
  • Loc: Arizona
Posted 08 April 2021 - 04:48 PM
Great work and image Mert! Especially with your conditions!
#14 Lead_Weight
Lead_Weight
  • Loc: Houston
Posted 08 April 2021 - 05:16 PM
Hi Lead-weight,
Yeah, It's got a blue tint to it. Photometric Color Calibration should do the trick.
#15 Mert
Mert
Posted 08 April 2021 - 05:40 PM
Oh well, let's see if I can use that since at first it all went green with
PCC.
I am finishing a second version of the processing working on the
background, looks like it has color blotches.
Anyway, this was taken from the balcony with quit some LP so
this is likely the best I can do with it until I gather more integration
time for it. ( hope to get > 30 hours as was suggested )
Tomorrow I will post V2 here and hope you give it a look
and let me know!
How does this version look? I tried to get some more faint details
and did noise reduction with EZ denoise.
Edited by Mert, 08 April 2021 - 05:47 PM.
  • elmiko and neaptide like this
#16 Mert
Mert
Posted 09 April 2021 - 06:42 AM
Just for fun I reprocessed from scratch, this time with PCC
and many other tricks.
This version is a smaller crop to get rid of some of these
ugly gradients I had to work with.
Always learning more things.
  • neaptide, Lead_Weight and ziggeman like this
#17 neaptide
neaptide
  • Loc: NY
Posted 09 April 2021 - 06:50 AM
Nice image As it is now Mert!! Looking forward to seeing how it turns out after more integration
#18 Mert
Mert
Posted 09 April 2021 - 07:46 AM
Thanks John,
I will certainly add much more time to this object hoping to
be able to reveal more of the faint structure.
  • neaptide likes this
