Time for a new HomeBrew project!
This will be an easy one: I will take an old-school switch-based joystick game controller, intended for an Atari 2600, and combine it with a small Arduino to interface it to the Celestron AUX bus. This controller will then be used for quick and easy slewing of the scope while at the mount, as an alternative to using a hand-controller or touch-screen.
I have ordered one two of these joysticks for under CAD$11/each (on sale right now):
https://www.amazon.c...uct/B07R21XWDS/
I will combine it with a $10 5V/16Mhz Arduino Pro Mini or Pro Micro board, hopefully being able to actually incorporate the Arduino inside the joystick casing, and use the original joystick cable to connect to the mount (with a new plug on the end). There's a single red button on the joystick, which I'm thinking could be used to select between fast/slow slewing speeds. And possibly another mode (?) when held down while using the joystick.
Wiring will be very very simple, so feel free to join in if you want to play along and make one for yourself.
The Joystick is due here on Tuesday April 13.
Edited by mlord, 10 April 2021 - 08:55 PM.
