QHY268M Characterization - Deviation of Specifications
Astrophotography CMOS Imaging Equipment
12 replies to this topic
#1 BenKolt
BenKolt
Posted 10 April 2021 - 10:42 PM
Greetings!
I received my QHY268M a couple of weeks ago but have only just now received all the other new equipment that I needed in order to start imaging with it.  Hopefully, that can start tomorrow night.
In the meantime, I wished to characterize my camera by measuring the gain, read noise, full well capacity, dynamic range and dark current.  The QHY website shows these specifications in plots for the four readout modes of the camera vs. the camera's gain parameter setting.  I wanted to confirm whether or not my camera meets these specs.  It turns out that my measurements show a deviation, and I thought this might be of interest to other owners of this camera.  I invite others to test their cameras to see if there may be some variability from camera to camera in these specifications or if there may be a discrepancy on the QHY website.
I will be imaging in Mode 1 (High Gain Mode), at least at first, and so I restricted my testing to this mode.  I varied the gain parameter from 0 to 100 in steps of 5 but used steps of 1 between 50 and 60 in anticipation of the camera's transition through these values.  I cooled the camera to -10C, and I adjusted the offset as I changed the gain parameter in order not to cut off pixels.  For the following results I used (mostly) the equations for basic camera characterization from Berry and Burnell, The Handbook of Astronomical Image Processing, Section 8.2.  The results compared well with PixInsight's BasciCCDParameter script with the exception of the dark current, where the script version I used to check my results is known to be in error.
For each gain parameter value I took two bias frames, a dark frame with 60s exposure, another dark frame with 600s exposure, and two flat frames with peak illumination set at about 30,000 [ADU].
The first is a plot of measured gain in units of [e-/ADU] vs. the camera's gain setting.
The first thing I noticed is that in this mode I am not getting a gain of about 1 [e-/ADU] at gain parameter 0 as QHY's plot suggests.  Instead, I am getting about 0.76 [e-/ADU] or so.  Next is my measured full well capacity:
Due to my smaller gain, my peak full well capacity at gain parameter 0 is about 50 ke-, not the 62 ke- or so from the QHY plot.  I note, however, that in the specification table, QHY lists two full well values, one at 51 ke-, the other at 75 ke- for extended full well mode.  My value agrees quite well with QHY's lower full well from the table, which does not correspond with any of the peak values from the plots for any of the modes.  I am unable to reconcile this difference on the QHY website.
Next is my read noise measure, which agrees quite well with the QHY plots:
I only measured dark current at the -10C cooling temperature, although I did measure it at difference gain parameter settings.  For the most part over my range of gain parameter values, the dark current was mostly constant, although the value dropped for large gain parameter values.  I don't know what that means, but the more constant answer is about 0.0016 e-/px/s, which is just a little higher than QHY's published value of 0.0013 e-/px/s at this temperature.
Next is the dynamic range, which I plot three different ways: in steps, dB and stops.  The last plot in stops agrees well with QHY's values.
It is this last plot in particular that shows the interest many have expressed in operating the camera in Mode 1 with gain parameter setting of 0 or 56 in order to maximize the dynamic range.  I look forward to trying this out starting tomorrow night if all goes well.
Again, I invite you to make some measurements of your QHY268M cameras to see if your specifications agree with mine or perhaps establish how much variability there is in the specs.  Thank you!
Best Regards,
Ben
Edited by BenKolt, 10 April 2021 - 10:45 PM.
  • BobT, SeymoreStars, munkacsymj and 2 others like this
#2 munkacsymj
munkacsymj
  • Loc: Rhode Island, USA
Posted 12 April 2021 - 08:53 PM
Ben:
Thanks for a beautiful job characterizing this camera. Your numbers are almost exactly the same as mine (although I haven't covered the entire range as you have). I tested mode 1 gain 0 and mode 1 gain 56:
Mode 1 gain 0:
read noise = 3.6 e-/pixel
system gain = 0.78 e-/ADU
Mode 1 gain 56:
read noise = 1.69 e-/pixel
system gain = 0.35 e-/ADU
- Mark M
#3 BenKolt
BenKolt
Posted 12 April 2021 - 09:50 PM
Ben:
Mode 1 gain 0:
Mode 1 gain 56:
- Mark M
Thanks for the remarks and for adding your results, Mark.  Very interesting that you get the same system gains as I.  I wonder if the QHY plots may be of an earlier test model and that the product set point is now for a smaller gain as we are measuring.  I'm certainly using my numbers for planning and operation.
Ben
#4 2ghouls
2ghouls
Posted 13 April 2021 - 06:52 AM
Here's mine:
Mode 1 gain 0:
read noise = 3.465 e-/pixel
system gain = 0.780 e-/ADU
Mode 1 gain 56:
read noise = 1.562 e-/pixel
system gain = 0.334 e-/ADU
-Nico
Sent from my VOG-L29 using Tapatalk
#5 BenKolt
BenKolt
Posted 13 April 2021 - 09:52 AM
Here's mine:
Mode 1 gain 0:
Mode 1 gain 56:
-Nico
Thanks for posting your numbers, Nico!  That's three of us now that are getting very similar results that deviate from QHY's posted plots on their website.  I'm wondering if they performed testing on an earlier model and that there were some adjustments made to the final released model that we all have.  These differences are in no way an issue because the dynamic range I measure is very similar to what they advertise.  What differs may be choices and expectations on camera performance and operation for a given set of parameters.  Nothing beats characterizing your own camera to finalize your understanding!
I reached out to QHY last week to let them see my results and to ask if they can reconcile the differences.  I'll post something if they respond.  I'm sure they're quite busy and may not be able to get back to me about such detailed testing.
Best Regards,
Ben
  • rockstarbill likes this
#6 pcalexander
pcalexander
  • Loc: South Carolina
Posted 18 April 2021 - 11:02 AM
I ran the SharpCap analysis two days ago and then once again last night.
First run - Mode 1, Gain 0 at -10C:
Read noise (e): 4.03
e/ADU: 0.79
Full Well (e): 52035.91
Dynamic Stops: 13.66
Second run - Mode 1, Gain 0 at -10C:
Read noise (e): 3.49
e/ADU: 0.88
Full Well (e): 57939.56
Dynamic Stops: 14.02
These runs weren't done at exactly the same flat panel brightness, but it was following the SharpCap prompts. I haven't run this test on other cameras that I've owned, so I am not sure what variances I am introducing myself, and I'm not sure if the variant results are typical when running the sensor analysis tool.
Phillip
#7 pcalexander
pcalexander
Posted 18 April 2021 - 11:11 AM
e/ADU: 0.79
e/ADU: 0.88
Phillip
Full sensor analysis results attached.
  • Miguelo and SilverLitz like this
#8 BenKolt
BenKolt
Posted 25 April 2021 - 04:16 PM
pcalexander:
Thank you for posting these results.  It's interesting to me how these two runs with SharpCap differ by so much.  Do you know if SharpCap performs an analysis over the whole sensor or just over a region of it?  For my calculations I picked one region of the sensor's field and stuck with it.  I had intended on doing at least one more pass through all the calculations on a different region in order to evaluate the variability.  I imagine there is wisdom in keeping away from the edges.
Ben
#9 pcalexander
pcalexander
Posted 25 April 2021 - 05:06 PM
That is a good point. I wasn’t even thinking about that. The sharpcap tool uses a region that you select yourself. You can change the size and a region of the test. I know that I did not have the same region selected across the two tests, but both were towards the center of the sensor.
#10 carballada
carballada
Posted 30 April 2021 - 05:02 AM
My results
mode1 gain 56 offset 25 at -5º
gain 0.331 e/ADU
readout noise 1.725 e / 5.213 ADU
fullwell 21688 e
dynamic range 12571 steps
mode1 gain 0 offset 25 at -5º
gain 0.764 e/ADU
readout noise 3.728 e / 4.877 ADU
fullwell 50097 e
dynamic range 13439 steps
Updated with more gain values close to 56
Edited by carballada, 30 April 2021 - 07:52 AM.
#11 BenKolt
BenKolt
Posted 30 April 2021 - 11:23 AM
My results
gain 0.331 e/ADU
fullwell 21688 e
gain 0.764 e/ADU
fullwell 50097 e
Thanks for posting your results, carballada!  Your values are close to the other sets listed in this thread.
Ben
  • carballada likes this
#12 carballada
carballada
Posted 01 May 2021 - 09:26 AM
Ben
yes, and confirms that I will use 56-25 for narrow band and 0-25 to rgb in mode 1 :D
#13 jeffcrilly2
jeffcrilly2
Posted 06 May 2021 - 03:13 AM
Hi.. I just came across this thread last night and it looks like there's lots of good info here.
I got a QHY268M about a month ago and have been imaging (LRGB and some Ha) with :
Gain = 0
Offset = 30
ReadMode = PhotoGraphic DSO
After reading this thread, I ran SharpCap -> Sensor Analysis , and attached the results to this post.
I'm still trying to wrap my brain around how to interpret these results, which gain/offset values to use, and exposure times (tho my understand is exposure depends on object brightness).
If anyone has some pointers given these results, and values to use for DSO vs , such info would be appreciated.
I sorta need a "CMOS settings for the impatient imager" cheatsheet.
thx
-Jeff
Also tagged with one or more of these keywords: Astrophotography, CMOS, Imaging, Equipment
