ETX105 Power Supply
5 replies to this topic
#1 tyrosmick
tyrosmick
Posted 12 April 2021 - 01:31 PM
Hi all.
My son has an ETX105. Should the batteries be removed when using a power adapter?
There doesn’t appear to be any guidelines on the subject and I would not want him to inadvertently cause damage to the electric circuit by having two power sources running concurrently.
Many thanks in advance.
Mick
#2 NearVision
NearVision
  • Loc: SE Wisconsin
Posted 12 April 2021 - 05:01 PM
I don't think the power jack on the scope has a switch to disconnect the internal batteries. It wouldn't damage the circuit by having both power sources connected at the same time but it would not be good for the batteries. The power adapter would try to charge the batteries and they don't like that. Check the warnings on batteries.
One way to test is to have it running on batteries and then plug the connector from the power supply into the scope without having the power supply plugged into an AC outlet. If the scope goes dead then there is a switch inside the jack to disconnect the batteries. If the scope stays on then you would have  them both connected if you plugged in the power supply which would not be good for the batteries and may damage the scope if they burn or worse.
#3 tyrosmick
tyrosmick
Posted 13 April 2021 - 12:59 AM
Thank you NearVision. Your advice is spot on! Inserting the jack does indeed disconnect the battery pack.
I am very grateful, your help much appreciated, thank you.
  • NearVision likes this
#4 greghoro
greghoro
Posted 13 April 2021 - 09:57 AM
Which brings up the question of whether the scope loses power momentarily when plugging or unplugging the external power source. And is there a risk of losing the alignment info in the processing of switching.
Scenario - you set up and align the scope on internal batteries but then plug in the external power for observing.
Greg
#5 greghoro
greghoro
Posted 13 April 2021 - 10:20 AM
While not for an ETX, I've attached the power board schematic for an LX90, which should be the same. Shows that the negative side of the connection controls which power is utilized.
Greg
#6 NearVision
NearVision
  • Loc: SE Wisconsin
Posted 13 April 2021 - 12:20 PM
The test I had tyrosmick do was only to confirm if the power jack has a switch builtin to disconnect the battery. It's most likely very similar to the schematic for the LX90 which shows the switch on the negative leg. Meade tends to stick with similar designs throughout their lines.
As to if the scope will retain it's settings if you do a 'hot plug' for switching power... It might. ('Hot plugging' is when you have something running and quickly switch a connection to something else. If you've ever heard a loud thump when someone plugs in a microphone or something else to a speaker system, that's a good example of bad hot plugging.) It depends on how long the circuit is open when the switch changes position when you plug in the AC power adapter. This is dependent on a number of things.
  • Does the power jack make the connection for power before it disconnects the battery? If so then there is no disruption of power to the scope and the second or less that both power sources are connected won't matter so the scope sees continued power and everybody's happy!
  • If the power jack disconnects the battery before it starts supplying power to the scope then it's a function of the circuitry in the scope being able to remember everything for the short time it's without power. Keep in mind that what we consider a short time (less than a second) can be an eternity for electronics that can do multiple things in a thousandth of a second.
The bottom line for me is to try not to do 'hot plugging' and shut down the equipment before connecting a different power source unless I know that the equipment will tolerate it well. Connecting power while it's working can also possibly create spikes or sags on the power supply which can have anywhere from no to very severe affects on the system and the power supply. This is less likely with most scopes because of the relatively simple power circuit requirements. But I like being paranoid sometimes! :)
