AP keypad button not responding
6 replies to this topic
#1 muller
muller
Posted 13 April 2021 - 05:41 AM
I am posting here because I have a wonderful AP MachOne mount (CP3GTO), but now having a problem with the keypad: one button, for slewing in declination (S), is not working properly. After some long period (days) of not using the mount and keypad, pushing the button does not give any response, and there is no way to slew in that direction. Other three buttons are always working.
It is only after I twist the keypad quite heavily in some ways, that I manage to get it back working.
So, I am thinking of some problems of connection inside the keypad. Unfortunately, it looks pretty complicated inside ...
Wanted to know if this problem also occurred to some of you, and what would be best to do: order a new one, try to get a fix from AP, or switch to a new control system of the mount ?
Thanks in advance for your suggestions !
#2 Bean614
Bean614
  • Loc: Mass.
Posted 13 April 2021 - 05:49 AM
DeOxit contact cleaner (for the pads too) is your friend.
#3 WadeH237
WadeH237
  • Loc: Ellensburg, WA
Posted 13 April 2021 - 08:30 AM
That sounds like a faulty connection problem.  Perhaps the keypad cable needs to be replaced.
You should contact Astro-Physics directly.  They will take care of you.
#4 jdupton
jdupton
  • Loc: Central Texas, USA
Posted 13 April 2021 - 08:48 AM
muller,
   This is probably a job for Astro-Physics to handle. It sounds like you may have opened up the back already and had a look inside. It is indeed quite complicated. Give AP a call and see if there is anything a user can try. They can also give you an estimate of the cost to clean and refurbish the KeyPad.
Bean614,
   This is really a bad idea. I expect that you have never seen the inside of the AP KeyPad. It is pretty difficult to get to the switches in the first place. (I don't even know for sure whether they are even a membrane type switch.) There are bundles of optical fibers in the KeyPad that complicate getting to things and I cannot imagine the damage that might be done by randomly spraying a contact cleaner into the assembly.
   To get an idea of what you face once the device is opened up, see the KeyPad Maintenance  Manual document on the AP Website.
   I agree with Wade, just call AP and see what they say...
John
Edited by jdupton, 13 April 2021 - 08:50 AM.
#5 alphatripleplus
alphatripleplus
    World Controller
  • Loc: Georgia
Posted 13 April 2021 - 12:48 PM
Agree with the above suggestion to call or email A-P. They are very responsive to phone calls in my experience.
#6 andysea
andysea
  • Loc: Seattle, WA
Posted 13 April 2021 - 02:13 PM
Yes call AP. The keypad on my 900 is a bit temperamental too. I believe the connections are fiber optics. AP can service it.
#7 Christopher Erickson
  • Loc: Waikoloa Village, Hawaii
Posted 13 April 2021 - 05:27 PM
AP hand controllers use fiber optics (light pipes) to illuminate the buttons but not for communications inside the unit.
This is not a cable issue. The coiled cable from the hand controller to the CP2/CP3/CP4/CP5 is RS-232. The information from all buttons and the controller itself all travel in the same transmit wire in the coiled cable.
This is a button contact issue. It is possible that a Q-tip can clean the button contact inside the controller. Depending on your electronics skills, it might be best for AP to deal with it.
  • jdupton likes this
