Question about adding finder
11 replies to this topic
#1 JustAnotherScott
JustAnotherScott
Posted 13 April 2021 - 10:46 AM
Not sure if this is best section so feel free to move mods sorry
I just picked up a vintage University Optics 80mm. Am I crazy to think it might be a good finder for my 10" dob?
With  32mm eyepiece I can get 16x and 4 degrees FOV. Combined with my telrad and some higher power eyepieces I think it would be a great combo for finding harder to see stuff.
Only issues I can see are:
How would I mount it? My DOB is a sonotube.
Balance would be an issue too. Its already out of balance from the telrad and I only have that marginally fixed.
Thoughts?
  • teashea likes this
#2 spereira
spereira
  • Loc: Bedford, NH
Posted 13 April 2021 - 10:50 AM
Moving to Equipment.
smp
  • JustAnotherScott likes this
#3 MellonLake
MellonLake
  • Loc: Toronto, Canada
Posted 13 April 2021 - 04:33 PM
I think you will run into balance issues with such a heavy telescope on a little Dob.  If you do mount it, mount it mid tube with the 80mm's centre of gravity over the trunnions.   Also the field of view is a little narrow, we are typically want more like 6°.
It is a really nice complimentary telescope though.  Great for large open clusters which can be difficult in the Dob (Pleiades, Beehive, etc.) and the moon.
Rob
  • paul hart and teashea like this
#4 CarolinaBanker
CarolinaBanker
  • Loc: Eastern North Carolina
Posted 13 April 2021 - 04:51 PM
Could you add some weight down low to offset it? I’d probably use a lighter finder though.
#5 teashea
teashea
  • Loc: Lincoln, Nebraska, USA
Posted 13 April 2021 - 08:42 PM
I would also think that the tube would have difficulty holding the weight without deforming.
  • Jon Isaacs likes this
#6 JustAnotherScott
JustAnotherScott
Posted 14 April 2021 - 09:21 AM
You might be be surprised its incredibly strong.
#7 JustAnotherScott
JustAnotherScott
Posted 14 April 2021 - 09:23 AM
Its tough to add weights to this set up. The mount doesn't have  a lot of room at the bottom and the tube is not ferrous.  I'm going to try a divers weight belt next time out.
Edited by JustAnotherScott, 14 April 2021 - 09:23 AM.
#8 JustAnotherScott
JustAnotherScott
Posted 14 April 2021 - 09:29 AM
Rob
My thinking is when combined with the telerad the 4 degrees wouldn't be an issue. I could buy a 2" eyepiece that would kick it up to around 5 degrees but they are expensive. I really want this to help me dial in on smaller objects.
Regarding the weight you are most like right especially with this set up. I am going to try some experiments with a divers belt counter weight system soon.
You were right about open clusters! I took it for a spin last night and the bee hive fit in it perfectly. It looked great!
#9 Jon Isaacs
Posted 14 April 2021 - 09:34 AM
The place for counterweights is the back side of the tube at 45 degrees so the weights fit in the corner of the rocker box when pointed near the zenith. This is also a good place balance-wise since it's opposite the finder/focuser.
The counterweights will need to be heavier than the 80 mm, diagonal,  eyepiece and finder rings.  If I remember correctly, the Deep Space Explorers had a low altitude bearing height so you might have to use 2x-3x the added weight top side.
#10 MellonLake
MellonLake
Posted 14 April 2021 - 09:51 AM
To Jon's point above, if your 80mm telescope weighs 8 lbs (just a guess) and you mount it at the front of the tube you will need to add 16 to 24lbs of weight to the rear of the tube (towards the front board on the rocker box).   Between the telescope and the weights you will be adding between 24lbs and 32lbs of weight to the system.  This is a lot of weight and will increase the weight of the telescope tube by more than 50%.  If you mount the telescope over the trunnions, the weight will not be as big of a factor.
I really would not front mount the 80mm telescope!  Mount it over the trunnions if you do want to mount it.  It may look weird but it will work the same way.
Edited by MellonLake, 14 April 2021 - 09:53 AM.
#11 JustAnotherScott
JustAnotherScott
Posted 14 April 2021 - 10:38 AM
Its around 3.5 pounds. You're correct putting it on the end would be an issue. After using it last night I think another issue will be the length of it. Its fun to filddle with though so I'll experiment.
#12 JustAnotherScott
JustAnotherScott
Posted 14 April 2021 - 10:41 AM
You're memory is correct Jon. Divers belt with weights seem to be the only thing I could use to position everything. Maybe its a completely silly idea we'll see. I could get a smaller RACI but whats the fun in that.
