Sigma Orionis ABCDE?
12 replies to this topic
#1 Gschnettler
Gschnettler
  • Loc: Cincinnati Ohio
Posted 13 April 2021 - 04:11 PM
When I look at Sigma Orionis, I can only see 4 of the 5 stars. And I’m not sure which ones I’m looking at. Maybe A, C, D and E? Does anyone have a diagram that labels the stars with their letters?
Is it even possible (with average amateur equipment) to see the 5th star?
#2 descott12
descott12
  • Loc: Charlotte, NC
Posted 13 April 2021 - 04:27 PM
Check out this post:
https://www.cloudyni...-the-trapezium/
Post #12 has them all marked. Pretty tricky with a camera. Not sure how it would go with an eyeball!
  • flt158 likes this
#3 MikiSJ
MikiSJ
  • Loc: San Jose, CA
Posted 13 April 2021 - 05:05 PM
When I was getting back into astronomy, an acquaintance invited me to look through her TEC 140. She pointed it at the 'Trap' and there was 5 stars, one blinking in an and out, such is the atmosphere of the Sierra Nevada foothills - but there it was.
This is a very tight star system and the less bright stars are buried in the glow of a brighter partner. Look for the bumps:
The above image is from post #12 at the link https://www.cloudyni...ium/?p=10900830
#4 ssmith
ssmith
  • Loc: Colorado
Posted 13 April 2021 - 05:06 PM
The AB pair with a 0.3” separation is a tough nut to crack with most amateur telescopes so the most you are likely to see is four stars with the AB pair being the brightest of the four.
Here is a photo:
  • payner, R Botero, chrysalis and 5 others like this
#5 Cotts
Cotts
    Just Wondering
  • Loc: Madoc, Ontario
Posted 13 April 2021 - 05:07 PM
Sigma Ori is not the Trapezium...
Sigma Ori AB is very tight, 0.3" off the top of my head.  So most folks see AB, C, D, and E....
Dave
  • Bonco2, flt158, Tyson M and 1 other like this
#6 descott12
descott12
Posted 13 April 2021 - 05:10 PM
Oops!!! My bad. I read the OP too fast...but still a challenge to split
  • flt158 likes this
#7 Gschnettler
Gschnettler
Posted 13 April 2021 - 07:38 PM
Thanks. I’ve been seeing AB, C, D and E in Sigma Ori. That helps! Not sure if I’ll ever be able to split AB.
Farther down in the constellation I’ve been able to see 6 stars in the Trapezium so I’m pretty happy about that. How hard is it to see 8 stars there? Is it worth attempting with my 12” dob? Would it require extra dark skies?
  • flt158 likes this
#8 fred1871
fred1871
  • Loc: Australia
Posted 14 April 2021 - 12:32 AM
The AB pair of Sigma Ori was discovered by SW Burnham (BU 1032 AB). He records it as a discovery with a 12-inch refractor (among the variety of scopes he used over time).
There's a calculated orbit available in the 6th Orbit Catalogue, and the diagram shows a near-circular orbit as seen from our vantage point in space. This means that the separation doesn't change very much. Magnitudes of the stars are given as 4.07 and 5.27, so there's enough difference to make it a bit tougher than a Dawes Limit (matched) object.
The Ephemeris gives a separation of 0.257" for each year 2019 to 2023, consistent with the near-circular orbit diagram. PA changes year by year - 248 for 2019.0 to 238.7 for 2023.0. The orbit calculation is Grade 2 so it should be good on predicting positions. Speckle measures of this pair from 1975 onwards show hardly any change in separation, just the noticeable continuing swing in PA over time.
So at a separation of near-enough 0.26" much of the time, that's the Dawes Limit for a rather larger scope than Burnham used to discover it; a 17.5-inch, not the 12 he used. Detecting elongation should however be possible with lesser scopes - the limit might be closer to a 10-inch, for which 0.26" is a whisker less than 0.5-Rayleigh. I'd think it worth trying with scopes in that range. Dawes for a 20-inch is ~0.23", so that should work for a bare split or near split, depending on the degree of extra difficulty from the brightness difference, which is helpfully moderate rather than large.
  • Bonco2, Magnus Ahrling, flt158 and 1 other like this
#9 Magnus Ahrling
Magnus Ahrling
  • Loc: Visby, Gotland, Sweden 57:30N.
Posted 16 April 2021 - 04:58 PM
Sigma is beutiful. AB,C,D and E in line are very pretty. But C is not to be taken for granted not even in my 8" scopes. Sometimes I almost must use "indirect" seeing to really notice it. But I am at 57N so this region is never high above horizion...
Trapezium...on rare occasions I have seen e and f in my 8" SCT and 8" f/6 Newtonian, never in my 6"Mak. Once again I am at 57N.
Clear Skies!
Magnus
PS Sigma AB? Well on a night with 10P and my fantasy & imagination ability is 100%, suresmile.gif
  • Bonco2, flt158 and rugby like this
#10 blakesphere
blakesphere
  • Loc: Toronto, Ontario
Posted 21 April 2021 - 02:09 PM
I imaged it in a 8-inch SCT - Canon 40D January this year in suburban skies.
https://1.bp.blogspo...0196+-+Copy.JPG
North bottom-left, east bottom-right.
AB not split.
A, C, D, and E are obvious.
cheers,
Blake
  • Bonco2, Magnus Ahrling and flt158 like this
#11 blakesphere
blakesphere
Posted 21 April 2021 - 02:10 PM
Full blog post.
http://blog.lumpydar...ttle-arrow.html
  • flt158 likes this
#12 Bonco2
Bonco2
Posted 21 April 2021 - 04:11 PM
Nice pictures and I like the wide view that shows the surrounding stars make it look like  a small version of Sagitta.
Bill
  • flt158 likes this
#13 sdcruz
sdcruz
  • Loc: Brisbane, AUS
Posted 27 April 2021 - 06:22 PM
Saw it last night with my 5inch Skywatcher Heritage - I am at -27 Degrees - looked amazing!
