hex focuser on ES 127 FCD-100 size
3 replies to this topic
#1 lowry_pt
lowry_pt
  • Loc: South of Indianapolis, IN
Posted 13 April 2021 - 06:23 PM
Does anyone know the THREAD size for the focuser?  I want to SCREW into the focuser not use the compression rings.
Thank you
Dawn
#2 photoracer18
photoracer18
  • Loc: Martinsburg, WV
Posted 13 April 2021 - 06:42 PM
You mean the thread size that is under the compression cap? Likely either 63mm or 68mm as those are the two most common threads. I know Moonlite uses 68mm and Starlight uses both depending on focuser size.  I know Stellarvue uses 63mm on every focuser up to and including 2.5" and I think WO does also. Best way is to find out if the maker has their own reducers and flatteners as FF and APS-C ones usually screw into the top of the focuser with the cap removed.
#3 TrustyChords
TrustyChords
Posted 13 April 2021 - 06:48 PM
My calipers measured about 67.5mm male thread diameter on my ES127 2.5" hex focuser, so I'd go with the 68mm measurement. Note: my calipers are not the most accurate to the mm.
  • lowry_pt likes this
#4 NUMBER26
NUMBER26
Posted 06 May 2021 - 12:52 PM
For ES127 FD100 CF I screw in at 68mm. Note that the threading on the tube was poor and it messed up. I have had to return the draw tube for replacement.
So take care. I believe the issue was caused by the poor quality extenders that came with the scope. I have replaced them with others from Baader. I needed about 127mm to help get back focus for the camera!
