Photoshop Image Stacking
Astrophotography Beginner DSLR Software
9 replies to this topic
#1 JimCase
JimCase
Posted 14 April 2021 - 11:18 AM
Has anyone used the image stacking function, which includes an alignment option, in Photoshop? It seems limited to ten images, but multiple tiff file stacks of up to ten images each can be stacked together if you do not check the “Create Smart Object” option when using a script.  I am trying to judge whether the Photoshop tools provide comparable results compared to other image processors on a MAC platform.
#2 terry59
terry59
  • Loc: Colorado, USA
Posted 14 April 2021 - 11:24 AM
I recommend PixInsight. I use both PI and PS but all of my calibration and stacking is done in PI
Edit: I do all of my non linear processing and my initial linear stretch in PI
Edited by terry59, 14 April 2021 - 11:55 AM.
#3 Tapio
Tapio
  • Loc: Tampere, Finland
Posted 14 April 2021 - 11:37 AM
Affinity Photo has stacking functions built in (for astronomy purposes).
#4 APshooter
APshooter
  • Loc: Camby, In.
Posted 14 April 2021 - 06:00 PM
Astro Pixel Processor
#5 cybermayberry
cybermayberry
Posted 14 April 2021 - 06:31 PM
https://www.youtube....yd5I_NPU&t=306s
It's not limited to 10 layers
Edited by cybermayberry, 14 April 2021 - 06:32 PM.
  • JimCase likes this
#6 JimCase
JimCase
Posted 14 April 2021 - 06:49 PM
Great. I will try using that approach to overcome the ten limitation. Do you find the quality of the output is comparable with the other tools people are using?
#7 cybermayberry
cybermayberry
Posted 14 April 2021 - 07:09 PM
I am a longtime user of Photoshop, but a pixinsight user for astrophotography. I have not tried Astro Pixel Processor personally, but pixinsight is superior to everything else I have ever tried.
I downloaded a trial from pixinsight a new after my first project they were getting my money.
I would recommend download trials of everything and see what works best for you
Edited by cybermayberry, 14 April 2021 - 07:10 PM.
#8 BQ Octantis
BQ Octantis
  • Loc: Red Centre, Oz
Posted 15 April 2021 - 12:28 AM
I started my foray into AP with an all-Photoshop flow. Manual alignment always did better for star fields—indeed, the auto alignment feature could never seem to find anything. For manual focus, set the upper layer to Lighten mode, align a star in one of the corners, and use the transformation tool with the transform center on that star to align the rest of the image. Be sure to set the mode back to Normal before combining layers.
Manual stacking is just an exercise in opacity. From the bottom, it goes 100%, 50%, 33%, 25%, 20%, 17%, 14%, 13%, 11%, 10%. Below that, representing the fractional contributions with 1 digit results in too much over or under representation of images; so I would just stack sets of 10 using the same rubric.
A better free stacker for MacOS is Lynkeos. It works great with 8-bit and 16-bit TIFFs and PNGs, but it chokes on .CR2 Canon raws (so I use RawTherapee 5.8.0 for calibration). Version 3.3 handles field rotation, but Version 2.10 is at least twice as fast for stacking planetary. For planetary, it handles the .mp4s out of AstroDSLR 1.3.
BQ
#9 T~Stew
T~Stew
  • Loc: central Ohio
Posted 15 April 2021 - 12:42 PM
Siril is free and is available for Mac I do believe. Very powerful software for stacking, preprocessing and post processing. And has an easy button if you use a script that does what you want to do.
#10 JimCase
JimCase
Posted 15 April 2021 - 01:00 PM
Thanks for all of your replies. It sounds while Photoshop can be used for stacking (and processing), the stacking tools in dedicated Astro software programs are preferred by many. I am continuing to explore several of these other software packages to see what the optimal solution is as I develop my workflow.
Also tagged with one or more of these keywords: Astrophotography, Beginner, DSLR, Software
